S3 업로드 마이그레이션이 DigitalOcean S3 Spaces에서 실패합니다
정보
  • 설치된 Discourse 버전: 2.5.0.beta2 [ 8b2e7483b2 ]
  • Digital Ocean 드롭렛 기본 설치
  • 프로세스 시작 직전에 새로 ./launcher/app rebuild 실행함
문제
script/discourse 작동하지 않음
이것은 제가 다음을 수행하는 것을 막고 있습니다.
root@clubcorsavenezuela-app:/var/www/discourse# script/discourse
Traceback (most recent call last):
        2: from script/discourse:4:in `<main>'
        1: from /usr/local/lib/ruby/site_ruby/2.6.0/rubygems/core_ext/kernel_require.rb:92:in `require'
/usr/local/lib/ruby/site_ruby/2.6.0/rubygems/core_ext/kernel_require.rb:92:in `require': cannot load such file -- thor (LoadError)
rake uploads:migrate_to_s3 작동하지 않음
사용된 명령어
먼저 테스트로 다음 명령어를 실행했습니다.
DISCOURSE_S3_ACCESS_KEY_ID="*****redacted****" \
DISCOURSE_S3_SECRET_ACCESS_KEY="*****redacted****" \
DISCOURSE_S3_REGION="us-east-1" \
DISCOURSE_S3_BUCKET="clubcorsavenezuela" \
DISCOURSE_S3_CDN_URL="https://cdn.clubcorsavenezuela.com" \
DRY_RUN=1 rake uploads:migrate_to_s3
문제
Updating the URLs in the database...
REPLACING '/uploads/default/original/' WITH '//clubcorsavenezuela.nyc3.digitaloceanspaces.com/uploads/original/'
REPLACING 'src="/uploads/default/original/(\dX/(?:[a-f0-9]/)*[a-f0-9]{40}[a-z0-9\.]*)' WITH 'src="//clubcorsavenezuela.nyc3.digitaloceanspaces.com/uploads/original/\1'
REPLACING 'src='/uploads/default/original/(\dX/(?:[a-f0-9]/)*[a-f0-9]{40}[a-z0-9\.]*)' WITH 'src='//clubcorsavenezuela.nyc3.digitaloceanspaces.com/uploads/original/\1'
REPLACING 'href="/uploads/default/original/(\dX/(?:[a-f0-9]/)*[a-f0-9]{40}[a-z0-9\.]*)' WITH 'href="//clubcorsavenezuela.nyc3.digitaloceanspaces.com/uploads/original/\1'
REPLACING 'href='/uploads/default/original/(\dX/(?:[a-f0-9]/)*[a-f0-9]{40}[a-z0-9\.]*)' WITH 'href='//clubcorsavenezuela.nyc3.digitaloceanspaces.com/uploads/original/\1'
REPLACING '\[img\]/uploads/default/original/(\dX/(?:[a-f0-9]/)*[a-f0-9]{40}[a-z0-9\.]*)\[/img\]' WITH '[img]//clubcorsavenezuela.nyc3.digitaloceanspaces.com/uploads/original/\1[/img]'
REMAPPING 'https://clubcorsavenezuela.com/uploads/default/original/' TO 'https://cdn.clubcorsavenezuela.com/original/'
rake aborted!
FileStore::ToS3MigrationError: 2264 of 2271 uploads are not migrated to S3. S3 migration failed for db 'default'.
/var/www/discourse/lib/file_store/to_s3_migration.rb:129:in `raise_or_log'
/var/www/discourse/lib/file_store/to_s3_migration.rb:76:in `migration_successful?'
/var/www/discourse/lib/file_store/to_s3_migration.rb:349:in `migrate_to_s3'
/var/www/discourse/lib/file_store/to_s3_migration.rb:63:in `migrate'
/var/www/discourse/lib/tasks/uploads.rake:239:in `migrate_to_s3'
/var/www/discourse/lib/tasks/uploads.rake:218:in `block in migrate_to_s3_all_sites'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.1.1/lib/rails_multisite/connection_management.rb:64:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.1.1/lib/rails_multisite/connection_management.rb:74:in `each_connection'
/var/www/discourse/lib/tasks/uploads.rake:216:in `migrate_to_s3_all_sites'
/var/www/discourse/lib/tasks/uploads.rake:212:in `block in <top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => uploads:migrate_to_s3
DRY_RUN=0을 사용할 때도 정확히 동일한 문제가 발생합니다.
