メッセージをキャンセルすると画面が暗くなる
Steps to repro:
Tap on the hamburger:
  • Go to Users
  • Click one profile
  • Try to open the message icon
  • Do not send the message, just press cancel
  • The screen will goes dim and you should either refresh or reopen the community to navigate again.
Using my iPhone 7 plus.
「いいね!」 1
Is this happening on meta?
Yes. It also happens in other forums. I can record it if that helps.
Please. I can’t repro off that for some reason. Unless it is a Apple only issue as I am on android.
動画では、画面が暗くなった後、プロフィールまたは Discourse のロゴを押してみますが、何も反応しません。
Im digging this currently, I think this is related to .card-cloak not being hidden in this case for some unknown reason, ATM.
My best guess is that something recently made https://github.com/discourse/discourse/blob/master/app/assets/javascripts/discourse/app/mixins/card-contents-base.js#L79 not working.
If I call this._hide() manually from close in user card component, it will correctly work.
「いいね!」 7
Ok this should get fixed by:
Thanks for report :+1:
「いいね!」 7
