SCSS variables referencing uploads broken in subfolder installs
Hi there,
After installing Discourse into a subfolder using DISCOURSE_RELATIVE_URL_ROOT, and then using a custom variable that references an uploaded file in Admin → Customize → Themes → Edit CSS/HTML, the URL generated in the CSS is wrong.
For example, if DISCOURSE_RELATIVE_URL_ROOT is /my/forum, the CSS generates a URL that looks like /my/forum/my/forum/uploads/default/original/1X/... (note the repeated relative URL root).
If S3 is used, the URL generated looks like /my/forum//something.dualstack.s3.amazonaws.com/uploads/default/original/1X/....
As a workaround, using an absolute URL (with the appropriate CORS configuration on S3) works.
3 לייקים
@tgxworld is that something that will be solved by your PR?
https://github.com/discourse/discourse/pull/6573
לייק 1
It wouldn’t solve the problem here since the PR deals only with site settings. @sam might have a better idea here since he worked on the upload assets support in themes.
לייק 1
@nbianca can you add that to your list? Makes sure you test both local and S3 uploads when using subfolder.
2 לייקים
Fixed by
https://github.com/discourse/discourse/pull/6622
5 לייקים
This topic was automatically closed after 2 days. New replies are no longer allowed.
