Search of category and user should return results
A bug was reported where searching with qualifiers like category and user returned no results, even with a valid query. peternlewis demonstrated this issue with a specific example, where a user searched for their posts in a particular category using username:myname category:mycategory. A workaround was found by adding the category name to the search query.
AmiAthena responded, but didn’t provide a solution to the bug.
However, sam confirmed that the issue was indeed a bug and planned to fix it. In a follow-up post, sam announced that the bug had already been fixed.
It seems that a search for nothing returns no result, and adding qualifiers like category and user still return nothing (this is related to the issues described at Search sometimes tokenizes unique user names and some times does not).
One of my forum users wants to see all their posts in a particular category, so they search for:
but that fails because there is no match.
A lousy workaround is to search for:
username:myname category:mycategory mycategory
Since mycategory always appears (or appears to appear) in the search matches, this finds everything.
But it seems to me that the search system should accept a search of only options.
Thanks.
1 curtida
This can be done by searching for the username within a category.
Yeah, I plan to fix this it is a bug
6 curtidas
Been fixed for a while now :slight_smile:
1 curtida
