Hello
Today, search return no result :
No results, and no “no result” message.
Spinner run one second, white line is added below search input, and no more…
With Mozilla Firefox I see network console.
Jquery returns “error 500”.
The log :
The query :
The answer :
An idea ?..
zogstrip
(Régis HANOL)
18 Marzo 2019, 3:07pm
It’s an internal server errors, so there should be something in your.discourse/logs.
I have a mistake similar to @Jean-Michel25 If you start the discourse in the development environment, then backtrace will appear in the browser console
ArgumentError at /search/query
wrong number of arguments (given 3, expected 1..2)
plugins/babble/app/models/group.rb, line 3
1 class ::Group
2 @@visible_group_scope = method(:visible_groups).clone
> 3 scope :visible_groups, ->(user, order = nil) {
4 @@visible_group_scope.call(user, order).where.not(visibility_level: 4)
5 }
6 end
App backtrace
- plugins/babble/app/models/group.rb:3:in `block in <class:Group>'
- lib/search.rb:710:in `groups_search'
- lib/search.rb:622:in `find_grouped_results'
- lib/search.rb:246:in `execute'
- plugins/babble/app/models/search.rb:4:in `execute'
- app/controllers/search_controller.rb:74:in `query'
- lib/middleware/omniauth_bypass_middleware.rb:32:in `call'
- lib/content_security_policy/middleware.rb:12:in `call'
- config/initializers/100-quiet_logger.rb:16:in `call'
- config/initializers/100-silence_logger.rb:29:in `call'
- lib/middleware/missing_avatars.rb:21:in `call'
- lib/middleware/turbo_dev.rb:34:in `call'
- bin/unicorn:48:in `load'
- bin/unicorn:48:in `<main>'
Full backtrace
- activerecord (5.2.2.1) lib/active_record/relation.rb:288:in `instance_exec'
- activerecord (5.2.2.1) lib/active_record/relation.rb:288:in `_exec_scope'
- activerecord (5.2.2.1) lib/active_record/scoping/named.rb:186:in `block in scope'
- actionpack (5.2.2.1) lib/action_controller/metal/basic_implicit_render.rb:6:in
`send_action'
- actionpack (5.2.2.1) lib/abstract_controller/base.rb:194:in `process_action'
- actionpack (5.2.2.1) lib/action_controller/metal/rendering.rb:30:in `process_action'
- actionpack (5.2.2.1) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
- activesupport (5.2.2.1) lib/active_support/callbacks.rb:132:in `run_callbacks'
- actionpack (5.2.2.1) lib/abstract_controller/callbacks.rb:41:in `process_action'
- actionpack (5.2.2.1) lib/action_controller/metal/rescue.rb:22:in `process_action'
- actionpack (5.2.2.1) lib/action_controller/metal/instrumentation.rb:34:in `block in
process_action'
- activesupport (5.2.2.1) lib/active_support/notifications.rb:168:in `block in instrument'
- activesupport (5.2.2.1) lib/active_support/notifications/instrumenter.rb:23:in
`instrument'
- activesupport (5.2.2.1) lib/active_support/notifications.rb:168:in `instrument'
- actionpack (5.2.2.1) lib/action_controller/metal/instrumentation.rb:32:in
`process_action'
- actionpack (5.2.2.1) lib/action_controller/metal/params_wrapper.rb:256:in
`process_action'
- activerecord (5.2.2.1) lib/active_record/railties/controller_runtime.rb:24:in
`process_action'
- actionpack (5.2.2.1) lib/abstract_controller/base.rb:134:in `process'
- actionview (5.2.2.1) lib/action_view/rendering.rb:32:in `process'
- rack-mini-profiler (1.0.2) lib/mini_profiler/profiling_methods.rb:104:in `block in
profile_method'
- actionpack (5.2.2.1) lib/action_controller/metal.rb:191:in `dispatch'
- actionpack (5.2.2.1) lib/action_controller/metal.rb:252:in `dispatch'
- actionpack (5.2.2.1) lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
- actionpack (5.2.2.1) lib/action_dispatch/routing/route_set.rb:34:in `serve'
- actionpack (5.2.2.1) lib/action_dispatch/journey/router.rb:52:in `block in serve'
- actionpack (5.2.2.1) lib/action_dispatch/journey/router.rb:35:in `each'
- actionpack (5.2.2.1) lib/action_dispatch/journey/router.rb:35:in `serve'
- actionpack (5.2.2.1) lib/action_dispatch/routing/route_set.rb:840:in `call'
- rack-protection (2.0.5) lib/rack/protection/frame_options.rb:31:in `call'
- rack (2.0.6) lib/rack/tempfile_reaper.rb:15:in `call'
- rack (2.0.6) lib/rack/conditional_get.rb:25:in `call'
- rack (2.0.6) lib/rack/head.rb:12:in `call'
- rack (2.0.6) lib/rack/session/abstract/id.rb:232:in `context'
- rack (2.0.6) lib/rack/session/abstract/id.rb:226:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/cookies.rb:670:in `call'
- activerecord (5.2.2.1) lib/active_record/migration.rb:559:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
- activesupport (5.2.2.1) lib/active_support/callbacks.rb:98:in `run_callbacks'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
- better_errors (2.5.0) lib/better_errors/middleware.rb:84:in `protected_app_call'
- better_errors (2.5.0) lib/better_errors/middleware.rb:79:in `better_errors_call'
- better_errors (2.5.0) lib/better_errors/middleware.rb:57:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
- logster (2.1.2) lib/logster/middleware/reporter.rb:30:in `call'
- railties (5.2.2.1) lib/rails/rack/logger.rb:38:in `call_app'
- railties (5.2.2.1) lib/rails/rack/logger.rb:28:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/request_id.rb:27:in `call'
- rack (2.0.6) lib/rack/method_override.rb:22:in `call'
- actionpack (5.2.2.1) lib/action_dispatch/middleware/static.rb:127:in `call'
- rack (2.0.6) lib/rack/sendfile.rb:111:in `call'
- rack-mini-profiler (1.0.2) lib/mini_profiler/profiler.rb:281:in `call'
- message_bus (2.2.0) lib/message_bus/rack/middleware.rb:57:in `call'
- railties (5.2.2.1) lib/rails/engine.rb:524:in `call'
- railties (5.2.2.1) lib/rails/railtie.rb:190:in `public_send'
- railties (5.2.2.1) lib/rails/railtie.rb:190:in `method_missing'
- rack (2.0.6) lib/rack/urlmap.rb:68:in `block in call'
- rack (2.0.6) lib/rack/urlmap.rb:53:in `each'
- rack (2.0.6) lib/rack/urlmap.rb:53:in `call'
- unicorn (5.4.1) lib/unicorn/http_server.rb:606:in `process_client'
- unicorn (5.4.1) lib/unicorn/http_server.rb:701:in `worker_loop'
- unicorn (5.4.1) lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
- unicorn (5.4.1) lib/unicorn/http_server.rb:142:in `start'
- unicorn (5.4.1) bin/unicorn:126:in `<top (required)>'
And the error is only when the babble plugin is installed
Remove this third party plugin and rebuild to fix the error.
