Search shows incorrect number of results until scrolled to bottom
Search first shows a smaller number of results, updates when you actually scrolled to the bottom.
Example:
First shows:
50 results for Did you remote debug the problem on the device already?"
When scrolled all the way down shows:
175 results for Did you remote debug the problem on the device already?"
If the number of real results is just unknown because of paging, I suggest showing “50+ results” as a workaround.
6 לייקים
Sure can you add this to your list @techapj? The suggestion to use 50+ is a good one. Low priority.
3 לייקים
Done via:
https://github.com/discourse/discourse/commit/89d1107f8131b416f4749f4f6aec4db342cbe009
7 לייקים
