Проблема с Select-kit в RTL
The list opened in Select-Kit is not displayed correctly in RTL.
Current layout:
| target |
|   popper    |
Expected layout:
     | target |
|   popper    |
I checked the code and saw that the settings are only for LTR.
And used here:
I tried to solve the problem by adding some CSS codes, but unfortunately, this causes more problems. I think if we use placement: "bottom-end" when the page is RTL, the problem will be solved.
Also, this has caused the opened poppers to be displayed off-screen on some mobile phones. If you need, I can send you some screenshots of the problem in a pm.
1 лайк
Can we apply this change to our community or must the change be applied by the Discourse team?
Yes you need to wait for a change, sorry, will try to have a look soon, should be trivial to fix.
1 лайк
Thank you for your response
Do you think it is possible to change such a thing through JavaScript? As we inject this change through a theme component to temporarily solve the problem.
Everything is possible but I wouldn’t recommend it, I will have a look shortly.
1 лайк
On desktops larger than 1711px, this problem is easily seen in the notification settings at the end of the topic page. :pray:
1 лайк
I pushed a fix on master for this, let me know if it improves the situation for you. If not please make sure you take a screenshot.
5 лайков
Due to the deletion of the gif profile pictures, we had to update with a slight delay. As it turns out, this problem is completely solved.
Thanks @j.jaffeux
2 лайка
