Send PM/@mention if a topic hasn't received any replies in X time?
Hi,
Is is possible to mention or send PMs to specific users if topic fitting specific category had got no replies for XX hours since first post?
This sounds like it should be possible, have you tried it to see if it could work?
I haven’t & plugin is not installed to our forum yet. I will certainly install it in upcoming forum re-build (we try to make it not as frequent) and will check if it’s possible myself.
I was asking to see if anybody know for sure, to skip installing plugin if it doesn’t cover such a task. The documentation on triggers & actions doesn’t seem to cover this use-case.
Okay, true. But you can add additional triggers to capture the use case you need. Currently, we do that by making a PR to the plugin.
