Yesterday we had an email to Discourse which errored out while processing with:
Unrecognized error type (RuntimeError: ) when processing incoming email
We only found out about this because the user looked on the site for their reply, couldn’t find it, and alerted me. While it did appear in the logs, I don’t check them particularly regularly.
The simplest ‘solution’ to this I see is sending a rejection message to users if there’s been any error during processing, telling them to try again or alert an admin.
Looking at the source, it seems like not sending a message when there’s an unrecognised error is intentional:
While I understand not giving specific information about the error isn’t really possible, Discourse should at least let the user know their email hasn’t been posted so they don’t naively assume it has.
I think the problem being raised isn’t so much the specific error, so much as who is notified when random unexpected errors occur. Only admins, if they look in the logs, get to see that the delivery has failed; senders just get radio silence:
Tipo di errore non riconosciuto (RuntimeError: ) durante l'elaborazione dell'e-mail in arrivo
Backtrace:
/var/www/discourse/lib/discourse.rb:26:in `execute_command'
/var/www/discourse/lib/upload_creator.rb:137:in `convert_to_jpeg!'
/var/www/discourse/lib/upload_creator.rb:42:in `block in create_for'
/var/www/discourse/lib/distributed_mutex.rb:21:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:5:in `synchronize'
/var/www/discourse/lib/upload_creator.rb:34:in `create_for'
/var/www/discourse/lib/email/receiver.rb:580:in `block in create_post_with_attachments'
/var/www/discourse/lib/email/receiver.rb:573:in `each'
/var/www/discourse/lib/email/receiver.rb:573:in `create_post_with_attachments'
/var/www/discourse/lib/email/receiver.rb:551:in `create_reply'
/var/www/discourse/lib/email/receiver.rb:101:in `process_internal'
/var/www/discourse/lib/email/receiver.rb:50:in `block in process!'
/var/www/discourse/lib/email/receiver.rb:45:in `process!'
/var/www/discourse/lib/email/processor.rb:17:in `process!'
/var/www/discourse/lib/email/processor.rb:11:in `process!'
/var/www/discourse/app/jobs/scheduled/poll_mailbox.rb:25:in `process_popmail'
/var/www/discourse/app/jobs/scheduled/poll_mailbox.rb:43:in `block (2 levels) in poll_pop3'
/usr/local/lib/ruby/2.4.0/net/pop.rb:689:in `block in delete_all'
/usr/local/lib/ruby/2.4.0/net/pop.rb:688:in `each'
/usr/local/lib/ruby/2.4.0/net/pop.rb:688:in `delete_all'
/var/www/discourse/app/jobs/scheduled/poll_mailbox.rb:42:in `block in poll_pop3'
/usr/local/lib/ruby/2.4.0/net/pop.rb:532:in `start'
/var/www/discourse/app/jobs/scheduled/poll_mailbox.rb:41:in `poll_pop3'
/var/www/discourse/app/jobs/scheduled/poll_mailbox.rb:16:in `execute'
/var/www/discourse/app/jobs/base.rb:154:in `block (2 levels) in perform'
È un errore strano e ho provato a riprodurlo con la stessa immagine, ma non ci sono riuscito. Quando l’utente ha reinviato l’e-mail, ha funzionato correttamente.
@zogstrip Ti invierò in privato i log completi, insieme all’e-mail grezza.
Come utente che utilizza solo l’e-mail, voglio che Discourse mi avvisi ogni volta che la mia e-mail non genera un post su Discourse, in modo da sapere che i miei colleghi non mi stanno semplicemente ignorando.
It hasn’t, but we want to ensure it doesn’t happen again.
And to be clear “it” isn’t this specific error, but the problem where an email-in will error out while processing and the user has no idea it hasn’t been posted:
It’s possibly easiest if I explain myself through code. Something like this is the feature I want to add:
(To be clear, this doesn’t actually implement the feature - templates, test and such still need to be written, and I’m not even sure if it’s the best way of approaching it - but hopefully it serves as a demonstration.)
@LeoMcA what do you think about adding the contact email site setting on the message?
So it will be:
We’re sorry, but your email message to %{destination} (titled %{former_title}) didn’t work.
There was an unrecognized error while processing your email and it wasn’t posted. You should try again, or contact a staff member at %{contact_mail}.
