SendGrid needs root cert installed
I am trying to set up my first discourse server, using docker and hosted in azure.
I have it running, but can’t get email to send from discourse. Looking at the production.log file in the container it appears that the problem is a lack of root cert packages in the Linux machine
Sent mail to someone@example.com (143.7ms)
Job exception: hostname "smtp.sendgrid.com" does not match the server certificate
Googling around seems to indicate the problem is that I need to install the Godaddy root cert in the container.
Does that seem correct? Why wouldn’t the standard root certs already be available?
That seems very strange, our image is based off Ubuntu, SSL connections work from the server to other spots.
We need to make SSL connections regularly to onebox links (do a search on oneboxing) do they work for you?
I don’t know that anything works, as I’ve been unable to validate my initial admin user.
You can validate it by hand if needed
./launcher enter app
rake admin:create
I’m rebuilding the container right now to not use TLS - but once it is running again I’ll try the rake command.
It may be (ok, it is) the case that I needed to use sendgrid.net rather than sendgrid.com as the smtp server :frowning:
