Background: I’m currently creating a solution that automatically deploys the nginx, uwsgi, flask, and discourse containers using docker-compose. My flask application has an oauth2 endpoint that discourse uses (using the discourse-oauth2-basic plugin) to authenticate users.
Question: Is there a way to automatically update settings pre/post install such as custom plugin settings like “oauth2 user id path”, default settings like “login required”, or creating/setting an api?
I assume it would also be valid to add - exec: rails r "SiteSetting.SomeSetting='value'"
to the yaml under “run:” as well? Or should this run in the after_code or after_bundle_exec hooks? I can’t seem to find documentation or the file that shows the valid hooks.
Did you have any success with this? I just restored a backup to another server and was effectively locked out due to the oauth2 hostname checking. I logged into the app and postgres directly to alter the setting, but being able to set it in the yaml would be much more appealing.
