Set up file and image uploads to S3
Is the fist post in the above
https://meta.discourse.org/t/set-up-file-and-image-uploads-to-s3
is still valid guide that allows admins to make it? If no, is there any other place where 2024 correct S3 guide is located? It is said that this is official and supported by Discource team.
we implemented it as in the above and and images are broken on discourse instance although they are being uploaded to S3.
Our flow
  1. Set up the S3 bucket itself and the policy in S3 as in the above (all steps are accurately followed)
  2. Set up the env in app.yml and in admin (identical) as in the above
  3. launcher rebuild app
  4. any CDN is NOT used at all as our understanding is that it is optional and it should work without CDN.
Result:
  1. Images are being uploaded to bucket by discourse
  2. links in posts are correctly replaced by Discourse to amazon links like
    xxx-bucket.s3.dualstack.us-east-1.amazonaws.com/original/1X/a1b21eb5de071799d4b5e5215619d11d28602dfe.jpeg
  3. links are not accessible (assumed because of the S3 policy in official guide)
Assumed change for the official S3 policy in guide . Principal: This policy does not specify a Principal, which means it applies to whoever has been authenticated with the right permissions. If to allow anonymous (public) access, we need to specify "Principal": "*". That also might not be good solution as it makes bucket public.
this is assumption as we appreciate if someone will update the guide to make it correct in 2024
Hey,
.we are using Cloudflare R2 for s3 storage(it works now) and i wanted to move discourse to another server.
However profile pictures were missing when restoring from a backup even when checking the “backup uploads” option.
so i ran the s3 migrate command on the old server to migrate images that are still local, and it’s failing with this trace, it’s not clear what’s the reason.
rake uploads:migrate_to_s3 --trace
** Invoke uploads:migrate_to_s3 (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute uploads:migrate_to_s3
Please note that migrating to S3 is currently not reversible!
[CTRL+c] to cancel, [ENTER] to continue
Migrating uploads to S3 for 'default'...
Uploading files to S3...
 - Listing local files
..... => 5123 files
 - Listing S3 files
....... => 6871 files
 - Syncing files to S3
.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................^[[B............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
Updating the URLs in the database...
Removing old optimized images...
Flagging all posts containing lightboxes for rebake...
828 posts were flagged for a rebake
rake aborted!
FileStore::ToS3MigrationError: 4898 of 5838 uploads are not migrated to S3. S3 migration failed for db 'default'. (FileStore::ToS3MigrationError)
/var/www/discourse/lib/file_store/to_s3_migration.rb:132:in `raise_or_log'
/var/www/discourse/lib/file_store/to_s3_migration.rb:73:in `migration_successful?'
/var/www/discourse/lib/file_store/to_s3_migration.rb:383:in `migrate_to_s3'
/var/www/discourse/lib/file_store/to_s3_migration.rb:59:in `migrate'
/var/www/discourse/lib/tasks/uploads.rake:126:in `migrate_to_s3'
/var/www/discourse/lib/tasks/uploads.rake:106:in `block in migrate_to_s3_all_sites'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:36:in `each_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `each_connection'
/var/www/discourse/lib/tasks/uploads.rake:104:in `migrate_to_s3_all_sites'
/var/www/discourse/lib/tasks/uploads.rake:100:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:455:in `exec'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor.rb:527:in `dispatch'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:35:in `dispatch'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:29:in `start'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:28:in `block in <top (required)>'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:20:in `<top (required)>'
it seems these pictures are still stored locally for some reason, even though i ran this migration script before.
My guess is that your changed something in your s3 setup and the missing images are on a different bucket or different path than the new ones.
You can look at
 Upload.pluck(:url)
To see what’s wrong, maybe
I recently had this same problem and was able to resolve the issue. I did so by updating the iam permissions with this role
  "Version": "2012-10-17",
  "Statement": [
      "Effect": "Allow",
      "Action": [
               "s3:List*",
               "s3:Get*",
               "s3:AbortMultipartUpload",
               "s3:DeleteObject",
               "s3:PutObject",
               "s3:PutObjectAcl",
               "s3:PutObjectVersionAcl",
               "s3:PutLifecycleConfiguration",
               "s3:CreateBucket",
               "s3:PutBucketCORS"
      "Resource": [
        "arn:aws:s3:::my-bucket",
        "arn:aws:s3:::my-bucket/*"
       "Effect": "Allow",
       "Action": [
           "s3:ListAllMyBuckets",
           "s3:ListBucket"
       "Resource": "*"
I also had to enable ACL object ownership
Here are my full configs when I search s3
Setup CORS on the bucket along with the above settings for multi-part uploads.
        "AllowedHeaders": [
            "content-type",
            "x-amz-acl",
            "x-amz-meta-sha1-checksum"
        "AllowedMethods": [
            "GET",
            "HEAD",
            "PUT"
        "AllowedOrigins": [
        "ExposeHeaders": [],
        "MaxAgeSeconds": 3000
Is it possible to change S3 service providers?
I’d like to know if there will be any issues if I try to change S3 service providers, ignoring the issue of already uploaded images. I don’t really have any major issues with this since the site isn’t up and running yet; I’m still developing it.
Is it possible to save the images locally and then activate S3 again with the new service provider?
You can set siteSettings.include_s3_uploads_in_backups=true in rails and then make a backup, change the S3 settings, and restore the backup.
Alright, I got it. Thanks a lot!
The linked thread mentions a PR to remove a migrate_from_s3 task, and I have seen no reason to believe it has been added back later, but I wanted to check if this was still the case. I am considering migrating to MinIO and am a bit concerned with making it a dependency.
I wonder if this could provide a workaround for what I mentioned above. Include that setting, make a backup, disable S3 settings, and restore the backup.
Yes. I would restore it to a new server so if something goes wrong you still have a working server.
From this thread, it seems that this setting downloads the individual files from S3, but I wonder if there might be issues with posts referencing S3 URLs rather than local files. I’m not sure how that is handled in the database. I would be interested to know if your migration to another provider was successful, @Rhod.
I made the transition smoothly. I emphasize that I didn’t have any major issues because the number of images or backups was minimal. The forum was entirely for testing purposes, not yet in “production”.
Finally, after several trials and errors, I reinstalled the forum on a new server (Hetzner) and configured Cloudflare S3 R2 (previously, I had Amazon S3), for backups and images with the server that finally convinced me.
I’m sorry I can’t be much help. I’ll see if I can test it on another server in the future.
With CF R2, do your chat thumbnails work fine?
I hadn’t noticed that error; the truth is I have the chat disabled on my site.
I don’t think I’ll be using it, but I still have the same error you mentioned in your post.
However, I’ll keep an eye on your post to see if they help you find a solution.
Thank you Walter! I came here to post the same only to see you’d already done so.
@Discourse any chance of getting the contents of Walter’s post integrated into the initial post?
我可以上传视频到S3上面吗?目前我上传视频 只有视频的封面图会传到S3上面 视频则传不上去
