Solved: Exited the chat bot from that telegram group. And understood that if I wanted the bot to be the part of that group, then that group’s chat ID need to have a channel and a channel rule under itself.
The Telegram integration works very well for channels but it’s unsuitable for groups-- it will spam its operation instructions every time a chat “event” happens (like someone joining or leaving the chat, or a message getting pinned). Even if you disable the slash commands entirely. Is there a way to get the bot to not respond to these events?
Do you have group_privacy disabled?
I tried that setting too and saw that it becomes every message as you say. Even with group_privacy enabled bots can still see these join/leave/pin events.
Hi,
I created the telegram bot, entered the key and activated the function in discourse. HTTPS is enabled (our site runs behind an apache proxy)
However the tab is not showing. Where can I debug this? I can not find any errors in the logs.
Is there a way to test the connection to telegram from inside the Discourse container?
thx
short update on this. I entered the discourse container with docker exec -it container /bin/bash. then I executed the following:
curl https://api.telegram.org/bot123456789:ABCDEfgh2ZojwyChMz0xuIo2Wvg4ww3XGI4g/getMe
this returned an ok response with the name of my bot etc.
however the integration with discourse does not work yet. Is there a log file somewhere so that I can debug this? Any help is appreciated.
Is the force_https site setting enabled? Is the chat_integration_enable_telegram setting enabled?
Hi,
yes both settings are enabled.
HTTPS is working fine, also with login integration with fb, google, tw.
what could be the cause, or where could I find the logs?
thx
I am also facing same issue since last 4-5 days on my new discourse instance.
Hi @david, is there any way i can see the logs.
On my old instance notifications are working good with telegram bot, but in newer instance Chat ID is not getting generated. The curl command mentioned above is giving output as true from discourse instance. Other oauth plugins like google. twitter are working without any issues.
Thanks in advance.
I just got it working on a new Discourse install by firing up rails c and manually running DiscourseChat::Provider::TelegramProvider.setup_webhook()
Hope that helps!
Thanks a lot @codatory
@codinghorror Thanks for this awesome platform ![]()
It worked ![]()
can you elaborate a bit on this? should I run these commands from within the container? in which directory? I’m not a rails expert. thx! : )
Yeah; so you enter the container and run
rails c
Then wait a bit for it to load up. Once it’s loaded up you can paste in
DiscourseChat::Provider::TelegramProvider.setup_webhook(); exit
Then you can exit out of the container and it should be working.
THANK YOU, this solved my issue But had to toggle the plugin off in my admin. Then on. Then run this.
Sono riuscito a farlo funzionare, ma non in un gruppo. Invia le notifiche direttamente a me come una chat tra me e il bot.
Ho aggiunto il bot a un gruppo privato e gli ho dato i privilegi di amministratore. Ho anche aggiunto il gruppo come canale nelle impostazioni del plugin Discourse. Tuttavia, ogni volta che provo a inviare una notifica di prova al gruppo (canale Telegram), ricevo l’errore 422. Non importa cosa faccia. Questo errore proviene dalle impostazioni del canale del plugin Telegram di Discourse.
Qualcuno può aiutarmi? Voglio davvero configurarlo per il nostro gruppo.
Questo problema dovrebbe ora essere risolto, grazie a questa PR:
Il problema più comune è una chiave API non valida. Assicurati di averla copiata e incollata correttamente e di non aver aggiunto accidentalmente spazi prima o dopo.
Il token API funziona correttamente, riesco a ricevere le notifiche in un messaggio privato dal bot su Telegram. Non riesce solo a inviare al gruppo. Inoltre, ogni volta che qualcuno nel canale invia un messaggio, il bot dice “Questo canale è configurato con chatID: …”, il che è molto fastidioso.
Ora sto ricevendo questo errore.
Errno::ECONNRESET: Connessione interrotta dal peer - SSL_connect
da /usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in `connect_nonblock’
Non importa come viene attivato o disattivato, sto riscontrando lo stesso problema. Esiste una soluzione alternativa?
Sto cercando di configurare le notifiche, ma quando aggiungo il bot al gruppo Telegram, non invia l’ID della chat. Ci ho provato più volte senza successo :<
Cosa posso fare per risolvere il problema? Ho già provato a eseguire il comando rails console
