Desactivar los correos electrónicos de resumen de forma predeterminada para nuevos usuarios
¿Dónde puedo establecer un valor predeterminado para esta configuración? Quiero desactivarlo de forma predeterminada para mis usuarios.
Screenshot_2018-09-06%20Profile%20-%20hosna%20-%20Discourse%20Meta
En la configuración del sitio, busca default email digest frequency y cámbialo a Nunca:
1 me gusta
But this is another settings. Its the frequency of sending email. I just want to disable it for new users. but let this frequency be what I want. I enable digest with api call.
I think that this is what you are looking for
Changing this setting means that, by default, all new users (starting after the setting is changed) will have the frequency set to ‘never’. The system is still running, but new users will not start to receive it unless they (or you via API) change their frequency
Does this fit your needs?
2 Me gusta
