Trying to setup discourse and cannot use it due to sso?
Trying to setup a discourse site, Its being routed through NGINX.
enable_discourse_id: Failed to automatically register with Discourse ID. This could be due to network connectivity issues, firewall restrictions, or the Discourse ID service being unreachable. Please check server logs for more details or contact support.
You have opted to skip setting up email for now. Unfortunately due to the error message above, the setup cannot continue. Please report this issue on meta.discourse.org.
My NGINX config, I’m not sure whats breaking SSO
server {
    server_name forum.website.net;
    location / {
        proxy_pass http://localhost:4180;
        #proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock:;
        proxy_set_header Host $http_host;
        proxy_http_version 1.1;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_set_header X-Real-IP $remote_addr;
    listen [::]:443 ssl; # managed by Certbot
    listen 443 ssl; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/forum.website.net/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/forum.website.net/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
    if ($host = forum.website.net) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
    listen 80; listen [::]:80;
    return 404; # managed by Certbot
I Have tried using unix socket ports from importing web.socketed.template.yml too
My app.yml config
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  #  - "templates/web.socketed.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "4180:80" # http
#  - "443:443" # https
params:
  #db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  ## Which Git revision should this container use? (default: latest)
  #version: latest
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 3
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: "forum.website.net"
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: "email@proton.me"
  ## TODO: Configure the mail server
  ##       (used for validation of new accounts, notifications, digests, etc.)
  ## required: hostname of the SMTP mail server used to send mail
  # DISCOURSE_SMTP_ADDRESS: smtp.example.com
  ## uncomment to set the port to something other than the default (25)
  #DISCOURSE_SMTP_PORT: 587
  ## USER_NAME / PASSWORD required if the SMTP provider needs authentication
  ## WARNING: a '#' in the SMTP password can be misinterpreted; ensure it's inside string quotes, e.g.:
  ##   DISCOURSE_SMTP_PASSWORD: "#pass#ord"
  # DISCOURSE_SMTP_USER_NAME: user@example.com
  # DISCOURSE_SMTP_PASSWORD: "pa$$word"
  ## uncomment to enable implicit TLS at connection time, probably needed for using port 465
  #DISCOURSE_SMTP_FORCE_TLS: true
  ## uncomment to set the HELO/EHLO domain, only set if required by provider
  #DISCOURSE_SMTP_DOMAIN: discourse.example.com
  ## the address from which notifications are sent
  #DISCOURSE_NOTIFICATION_EMAIL: noreply@discourse.example.com
  ## uncomment to change server certificate verification
  #DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: peer # peer|none
  ## uncomment to override the authentication method
  #DISCOURSE_SMTP_AUTHENTICATION: plain # plain|login|cram_md5
  # Optional email setup skip flag
  DISCOURSE_SKIP_EMAIL_SETUP: "1" # (optional), uncomment to skip email setup validation
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP account ID and license key for IP address lookups
  ## see https://meta.discourse.org/t/-/173941 for details
  #DISCOURSE_MAXMIND_ACCOUNT_ID: 123456
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
Anybody knows how to fix this? Also, I’m not going to use email signin/login anytime soon. So SSO only
