Setup wizard select bug
Hello
I’m setting up a new Discourse instance, and in the wizard, when trying to select the language, the wizard panel disappears when the select is opened and I type a letter
Steps to reproduce in macOS 10.13.3 (17D102), Chrome Version 65.0.3325.181 (Official Build) (64-bit)
  1. Open the setup wizard (/wizard)
  2. Click on the “What’s the default language for your community?” select box
  3. When opened and in focus, type the letter “e”, for example
Then, the panel disappears and the only thing left is the background image:
Before typing “e”
After
Note that this is only a minor inconvenience. If you don’t type any letter, you can still continue and do the setup without any problem. Still, a bug is a bug.
We have two reports like this one, definitely a recent regression. Will have a look at this monday, probably easy to fix. Maybe jquery upgrade related or not. Thanks for the detailed report.
Could never reproduce it but tried to make this codepath more resilient, let me know if it works. If it doesn’t please try to come up with a clear repro if possible.
https://github.com/discourse/discourse/commit/d54da517d9c58862a576174d1ae5b0c4d67641cb
Now working. Thanks a lot :+1:
