توقف 'Default Locale' عن العمل (مرة أخرى)
The Default Locale bug seems to have come back. Latest discourse, new install, I selected “Français” during the wizard setup, and got an English setup. So I went to the Admin settings and changed the default locale setting to ‘Français’ and saved… But I keep having the site in English. I tried with a new session in a private window: it’s English indeed.
Logs says:
An attempt was to change default_locale SiteSetting to fr however it is shadowed so this will be ignored!
c.f.: https://champs.lepiceriesansfin.org/logs/show/6ecaa9300a8ba60f634652f702149448
Solution
Hmm who should this be assigned to @sam?
@gerhard can you add to your list to investigate when you work on the TOS/FAQ stuff?
Could you please post the content of that log entry? Also, did you set DISCOURSE_DEFAULT_LOCALE in app.yml or is it still set to the default (# DISCOURSE_DEFAULT_LOCALE: en)?
Oh, that’s a bug in the wizard’s UI. Pressing Enter while selecting the locale forwards you to the next step without actually changing the locale. I’m going to fix this.
Be careful though that changing the locale through the admin interface fails as well!
I can’t reproduce that. Could you post the log entry please?
Are you using any non-official plugins?
Isn’t the link to the log available to you?
Yes there are some custom plugins, notably some by Angus. I’ll post the full list when I get back home…
Here is the full list:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone https://github.com/discourse/discourse-assign.git
          - git clone https://github.com/discourse/discourse-github-linkback.git
          - git clone https://github.com/discourse/discourse-policy.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-spoiler-alert.git
          - git clone https://github.com/discourse/discourse-voting.git
          - git clone https://github.com/angusmcleod/discourse-custom-wizard.git
          - git clone https://github.com/angusmcleod/discourse-events.git
          - git clone https://github.com/angusmcleod/discourse-locations.git
          - git clone https://github.com/cpradio/discourse-plugin-checklist.git
          - git clone https://github.com/davidtaylorhq/discourse-whos-online.git
#          - git clone https://github.com/lidel/discourse-openstreetmap.git
P.S.: I just tested again from the admin interface. The locale appears to be changed, but reloading the page puts it back to English.
That link only works for admins.
Message
Backtrace
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.11/lib/logster/logger.rb:94:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.11/lib/logster/logger.rb:51:in `add'
/usr/local/lib/ruby/2.5.0/logger.rb:536:in `warn'
/var/www/discourse/lib/site_setting_extension.rb:397:in `block in setup_shadowed_methods'
/var/www/discourse/lib/site_setting_extension.rb:347:in `set'
/var/www/discourse/lib/site_setting_extension.rb:356:in `set_and_log'
/var/www/discourse/lib/wizard/step_updater.rb:33:in `update_setting'
/var/www/discourse/lib/wizard/step_updater.rb:37:in `apply_setting'
/var/www/discourse/lib/wizard/builder.rb:28:in `block (2 levels) in build'
/var/www/discourse/lib/wizard/step_updater.rb:15:in `update'
/var/www/discourse/app/controllers/steps_controller.rb:14:in `update'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.0/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:214:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.11/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.5/lib/rails_multisite/middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:285:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.1.5/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:180:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>'
Env
hostname	ps-web
process_id	9776
application_version	07e11a223ceee1b62aaa2de18e8cf438893e9e82
HTTP_HOST	champs.lepiceriesansfin.org
REQUEST_URI	/wizard/steps/locale
REQUEST_METHOD	PUT
HTTP_USER_AGENT	Mozilla/5.0 (X11; Linux x86_64; rv:61.0) Gecko/20100101 Firefox/61.0
HTTP_ACCEPT	*/*
HTTP_REFERER	https://champs.lepiceriesansfin.org/wizard/steps/locale
HTTP_X_FORWARDED_FOR	176.156.211.225, 176.156.211.225
HTTP_X_REAL_IP	176.156.211.225
username	how
params	null
Here is the log from my most recent attempt:
Message
Backtrace
/var/www/discourse/app/controllers/admin/site_settings_controller.rb:16:in `update'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.4/lib/rails_multisite/middleware.rb:24:in `call'
Env
hostname	ps-web
process_id	3322
application_version	ecf60c0c33a8bfd391f37f931f5430b0617a9cb1
REQUEST_URI	/admin/site_settings/default_locale
REQUEST_METHOD	PUT
HTTP_ACCEPT	*/*
HTTP_REFERER	https://champs.lepiceriesansfin.org/admin/site_settings/category/required
HTTP_X_FORWARDED_FOR	212.239.136.241, 212.239.136.241
HTTP_X_REAL_IP	212.239.136.241
username	how
params	default_locale	fr
الرجاء إلقاء نظرة على ملف الإعداد لحاوية Discourse Docker (على الأرجح app.yml) والتأكد من أن DISCOURSE_DEFAULT_LOCALE مُعلَّق عليه. يجب أن يبدو كالتالي:
لن تتمكن من تغيير default_locale داخل Discourse عندما يتم تعيين متغير البيئة هذا.
@sam لا أعتقد أن هذا خطأ، ولكن قد تكون فكرة جيدة تعطيل تغيير اللغة المحلية لواجهة المستخدم (المعالج وإعدادات الموقع) إذا كانت مُظلَّلة. ستكون هناك حاجة أيضًا إلى تلميح لسبب تعطيله. ما رأيك؟
Sounds right to me should be removed from the UI
Thank you so much @gerhard, your answer was point blank!
So in order to run multiple instances in different languages, DISCOURSE_DEFAULT_LOCALE must be commented out in /var/discourse/containers/app.yml, or in my case, using multiple containers: /var/discourse/containers/web.yml.
(I guess this should move to Support and be closed.)
