Shortcode for Comments
The discussion revolves around the availability of a shortcode for displaying Discourse comments in WordPress. TEKFused asks if a shortcode exists for comments, particularly for use with a page builder and an LMS that don’t support blocks. angus explains that while a separate plugin exists for shortcodes, there is no shortcode for displaying comments from a specific topic. He suggests using reusable blocks in Beaver Builder as an alternative. TEKFused acknowledges the suggestion and requests an enhancement to the shortcode plugin to allow displaying comments from a specific topic using a post ID parameter.
I know there is a Discourse block for the comments, but is there a shortcode as well? If so, could you let me know where I can find the shortcode’s parameters? Thank you!
Hey @TEKFused, there is currently a separate plugin for WP Discourse shortcodes.
https://github.com/communiteq/wp-discourse-shortcodes
It’s on my overall agenda to merge this into the main WP Discourse plugin. However there isn’t a Comments shortcode that works in the way you’re anticipating.
Can I ask is there a reason you prefer shortcodes over the new block? In general Wordpress is moving away from shortcodes to blocks.
Angus, thank you! I’ll check out that plugin! Is there is a way to use one of those shortcodes to display a specific topic by using its URL?
The reason for my request is I’m using a page builder that doesn’t support blocks. The other issue is that I’m using a LMS that has a lecture description field which also doesn’t support blocks.
Hopefully that makes sense, thank you!
Jake
Hey Jake,
No there isn’t a shortcode for displaying the posts from a specific topic. I see from another topic that you’re using Beaver Builder. Have you tried using the reusable blocks module?
https://docs.wpbeaverbuilder.com/beaver-builder/layouts/modules/reusable-blocks/
Hi Angus, I wasn’t aware of their reusable block module, thank you!
I’d love to see the Discourse shortcode plugin enhanced so that we could have a shortcode used to show a topic’s comments, and have a parameter for a post ID (the default behavior would be to show the current post’s Discourse comments).
Thank you again!
Jake
