Moet Discourse moeite doen om een ​​levensvatbaar commentaarplatform te worden?
Thanks heaps for the report @Slaune, I managed to repro and fix it now
https://github.com/discourse/discourse/pull/38668
@here We swapped our blog comments to this new system!
See it live at any post, like Understanding Discourse Trust Levels , It’s Time We Talked About Tags or Introducing Discourse AI.
We are still adjusting the experience, first with a small theme component here on Meta and then will merge what makes sense as a default into core.
Eager to hear your feedback on this.
Wow, fully embedded native Topics with working progress bar navigation? Nice! :star_struck:
The only critiques I have is that I’m seeing a mix between light and dark theme? And the padding could do with some love?
Yes, we are adding forced light mode in our Meta theme-component as this instance is very liberal on color schemes. I had my profile set to use the dark color scheme even on the light mode, but after fixing that on my profile it is looking better.
100%, there are still places to fix, specially in our own branded theme.
