Should I disclose the numbers one should reach to get granted the highest trust level?
סיכום מבוסס בינה מלאכותית
The discussion revolves around whether to disclose the numbers required to reach the highest trust level in a community. meglio suggests that revealing the current settings could alleviate users’ concerns about biased trust level granting. pfaffman and JagWaugh agree that transparency would be beneficial. Johani adds that knowing the goal makes it easier to work towards it. However, Mittineague raises a potential issue with members who have their trust level locked, which pfaffman acknowledges as a valid point. tobiaseigen mentions a lesser-known fact about groups locking trust levels, but eviltrout clarifies that this bug has been fixed, and trust levels are now properly tracked.
People in our community sometimes think that the levels are not automatic, and there’s some bias in how levels are granted.
Is it a good idea to disclose the current settings for trust levels, so that users know what exactly they should do to reach some particular level?
I don’t see a problem. Most sites use the default values, so you’d not be revealing any secrets.
לייק 1
It’s probably easier to just reveal the settings, than to answer individual questions, or try to convince them that you’re not running some privately chosen starchamber.
5 לייקים
It’s easier to work towards a goal if you know what it is.
2 לייקים
One potential snag might be if you have any members that have their trust level locked. It could be awkward explaining to a member why even though they have met all the requirements they haven’t advanced.
3 לייקים
Well, in that case there would be some bias in how trust levels were awarded. :slight_smile:
לייק 1
It is a perhaps Little Known Fact™ that groups can be used to inadvertently lock the trust level when a user joins the group.
Personally I downplay the importance of trust levels.
I believe that bug was fixed @sam @eviltrout? I remember some discussion about it.
Yes this has been changed (although not for old records, because they were locked previously.)
We now track “locked in group” separately from “locked manually”. When you leave the group you are put back to what your trust level would have been.
8 לייקים
