Show an error page when rebuild
סיכום מבוסס בינה מלאכותית
The discussion revolves around showing an error page during a Discourse rebuild, particularly when a “502 Bad Gateway” error occurs. michael_solomon reports this issue after running ./launcher rebuild app, expressing frustration over the downtime. codinghorror questions the feasibility on a standard setup. watchmanmonitor suggests using a separate, SSL-secured one-page site to redirect during maintenance. riking proposes configuring NGINX to serve a custom 502 page with a refresh. codinghorror encourages submitting a feature request. sam notes this doesn’t address the core issue of container downtime. fefrei shares that this approach works for their setup with host-level nginx. Stephen argues it’s a temporary fix, as a 502 error indicates the service is down, and customers may still see errors.
Hi,
When I “./launcher rebuild app” my Discourse and try to enter to my Discourse forum, its shows “502 Bad Gateway” error.
I know it’s just 10 minutes but I think it’s more professional to show to our users a pretty error message when we update our Discourse.
Thanks you,
Miki
P.S: sorry for my lame english. working on it!
לייק 1
Is this even possible on the standard Docker install @sam or @riking?
לייק 1
For things like this, we maintain a fully separate one-page website with the same valid SSL certs as our app/site.
When it’s time for maintenance, we point DNS at that server, do our thing, and point it back. Requires a short TTL to make it worthwhile, but that works for us.
I suppose something like that could be done in a separate docker setup on the same host?
לייק 1
I suppose that the inner NGINX could have a 502 rule to serve a page like this:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="refresh" content="5">
</head>
<body>
The Discourse server is starting up, please wait.....
</body>
</html>
Because if you can see that page at all, it means that the container is running and Unicorn is unreachable.
5 לייקים
Yes why don’t you submit that change. Good idea!
לייק 1
Does not solve much, the issue is that the container must be stopped during rebuild of standalone
לייק 1
In my use case, that would help a lot: I use nginx running on the host since I serve multiple subdomains. This already shows a nice message while the container is down – but bad gateway still leaks through while the conainer starts up.
This is a band-aid at best.
If NGINX is serving a 502 at all then any customers using services such as Cloudflare will never see that error, they’ll see the 521 error from Cloudflare.
