Sidekiq-taak (Scores berekenen) faalt constant na PG15-migratie
Greetings. All of a sudden after migration to PSQL15 one of my jobs (Calculate Scores) are constantly failing:
Job exception: ERROR: could not open file "base/16384/544114.1" (target block 655360): previous segment is only 20325 blocks
Job exception: ERROR: could not open file "base/16384/544113.1" (target block 134235414): previous segment is only 41880 blocks
(no such files present in psql data folder)
Backtrace:
rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `exec'
rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `async_exec'
mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:217:in `run'
mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `block in run'
mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `block in with_lock'
activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `with_lock'
mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `run'
/var/www/discourse/lib/mini_sql_multisite_connection.rb:109:in `run'
mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:196:in `exec'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/builder.rb:62):2:in `exec'
/var/www/discourse/lib/score_calculator.rb:73:in `update_posts_rank'
/var/www/discourse/lib/score_calculator.rb:15:in `calculate'
/var/www/discourse/app/jobs/scheduled/calculate_scores.rb:8:in `execute'
/var/www/discourse/app/jobs/base.rb:316:in `block (2 levels) in perform'
rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/app/jobs/base.rb:303:in `block in perform'
/var/www/discourse/app/jobs/base.rb:299:in `each'
/var/www/discourse/app/jobs/base.rb:299:in `perform'
/var/www/discourse/app/jobs/base.rb:379:in `perform'
mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:137:in `process_queue'
mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:77:in `worker_loop'
mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:63:in `block (2 levels) in ensure_worker_threads'
Also, two of my users, considering no issues with their profiles, reporting 500 error while accessing their public profiles:
/u/username/summary.json
Any advise on fixing the situation?
Something’s wrong with your database file(s). You might want to investigate those first.
