Currently getting this bug
Running the latest discourse
and here is the /sidekiq
Are you running the recommended Docker-based install?
I’m facing the same problem. I didn’t have any problem before.
Also encounted such problem. Tried rebuild and restart, both not working.
This problem is the result of a query not being sent properly from the VersionCheck job. It is failing because when it goes to check the version, the query isn’t included and thus a bad response comes back. There was also an issue with the port number, IIRC. There is a pull request pending on the fix.
I did not make the fix, but I did manually apply the code changes to my install and it fixed the issue.
yes its the recommended docker based install
Yes let’s get this fixed asap @tgxworld
geez…I might just switch us to use Ruby’s built-in HTTP library. Just a simple get request and Excon gets in the way. Anyway, this has been fixed by @AlbertA in
Why do we even need a third party library for this?
It has sort of been the convention in our repository to use either RestClient or Excon to make external requests. These third party clients provide a wrapper around the HTTP library which usually makes the code less verbose. While that is true for RestClient, I don’t think the same can be said for Excon. However, we don’t like RestClient because it depends on the mime-type gem that takes up quite a bit of memory. Once the latest mail gem is released, we’ll be able to drop the dependency on mime-type and switch to @sam’s mini-mime gem.
I am currently getting the same issue, even after rebuilding the container from SSH to latest.
Any errors in your logs?
i am getting this when running
./launcher logs app
ok: run: postgres: (pid 214) 1s
supervisor pid: 208 unicorn pid: 233
2017-06-19 08:17:50.172 UTC [375] discourse@discourse LOG: duration: 105.753 ms execute <unnamed>: SELECT "posts".* FROM "posts" WHERE ("posts"."deleted_at" IS NULL) AND "posts"."user_deleted" = 't' AND "posts"."deleted_at" IS NULL AND (NOT EXISTS (
SELECT 1 FROM topics t
WHERE t.deleted_at IS NOT NULL AND
t.id = posts.topic_id
)) AND (updated_at < '2017-06-18 08:17:50.022112' AND post_number > 1) AND (NOT EXISTS (
SELECT 1
FROM post_actions pa
WHERE pa.post_id = posts.id AND
pa.deleted_at IS NULL AND
pa.post_action_type_id IN (3,4,7,8)
)) ORDER BY "posts"."id" ASC LIMIT 1000
206:M 19 Jun 08:22:28.041 * 10 changes in 300 seconds. Saving...
206:M 19 Jun 08:22:28.054 * Background saving started by pid 1394
1394:C 19 Jun 08:22:28.336 * DB saved on disk
1394:C 19 Jun 08:22:28.337 * RDB: 30 MB of memory used by copy-on-write
206:M 19 Jun 08:22:28.368 * Background saving terminated with success
206:M 19 Jun 08:27:29.005 * 10 changes in 300 seconds. Saving...
206:M 19 Jun 08:27:29.010 * Background saving started by pid 1808
1808:C 19 Jun 08:27:29.248 * DB saved on disk
1808:C 19 Jun 08:27:29.249 * RDB: 30 MB of memory used by copy-on-write
206:M 19 Jun 08:27:29.321 * Background saving terminated with success
206:M 19 Jun 08:32:30.070 * 10 changes in 300 seconds. Saving...
206:M 19 Jun 08:32:30.072 * Background saving started by pid 2167
2167:C 19 Jun 08:32:30.369 * DB saved on disk
2167:C 19 Jun 08:32:30.370 * RDB: 32 MB of memory used by copy-on-write
206:M 19 Jun 08:32:30.420 * Background saving terminated with success
206:M 19 Jun 08:37:31.100 * 10 changes in 300 seconds. Saving...
206:M 19 Jun 08:37:31.104 * Background saving started by pid 2508
2508:C 19 Jun 08:37:31.458 * DB saved on disk
2508:C 19 Jun 08:37:31.461 * RDB: 36 MB of memory used by copy-on-write
206:M 19 Jun 08:37:31.511 * Background saving terminated with success
206:M 19 Jun 08:42:32.022 * 10 changes in 300 seconds. Saving...
206:M 19 Jun 08:42:32.032 * Background saving started by pid 2859
2859:C 19 Jun 08:42:32.400 * DB saved on disk
2859:C 19 Jun 08:42:32.402 * RDB: 36 MB of memory used by copy-on-write
206:M 19 Jun 08:42:32.440 * Background saving terminated with success
206:M 19 Jun 08:47:33.096 * 10 changes in 300 seconds. Saving...
206:M 19 Jun 08:47:33.099 * Background saving started by pid 3339
3339:C 19 Jun 08:47:33.339 * DB saved on disk
3339:C 19 Jun 08:47:33.340 * RDB: 32 MB of memory used by copy-on-write
206:M 19 Jun 08:47:33.402 * Background saving terminated with success
Oops I meant the logs at /logs
This is it
Message
Discourse::InvalidAccess (Discourse::InvalidAccess)
/var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/application_controller.rb:20:in `ensure_admin'
Backtrace
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:432:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:164:in `block in halting'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:504:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:504:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:504:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-4.2.8/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-4.2.8/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-0.10.5/lib/mini_profiler/profiling_methods.rb:102:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-4.2.8/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-4.2.8/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-4.2.8/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/routing/mapper.rb:51:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:189:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:167:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/omniauth-1.6.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/conditionalget.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:147:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-4.2.8/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-4.2.8/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-4.2.8/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.7/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-4.2.8/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-4.2.8/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:17:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-0.10.5/lib/mini_profiler/profiler.rb:282:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.0.2/lib/message_bus/rack/middleware.rb:62:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-4.2.8/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-1.6.8/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:702:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:22:in `load'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:22:in `<main>'
Env
hostname discussmoe-1473747263075-2gb-ams2-01-app
process_id 10292
application_version 0829bb86586615e63c9223fd79d3a9869423f50a
HTTP_HOST discuss.moe
REQUEST_URI /admin/upgrade
REQUEST_METHOD GET
HTTP_USER_AGENT Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36
HTTP_ACCEPT text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
HTTP_X_FORWARDED_FOR xxxxxxxxxxxxxxx
HTTP_X_REAL_IP xxxxxxxxx
Message (3 copies reported)
Job exception: Failed to open TCP connection to blog.discuss.moe:443 (getaddrinfo: No address associated with hostname)
Backtrace
/usr/local/lib/ruby/2.4.0/net/http.rb:906:in `rescue in block in connect'
/usr/local/lib/ruby/2.4.0/net/http.rb:903:in `block in connect'
/usr/local/lib/ruby/2.4.0/timeout.rb:93:in `block in timeout'
/usr/local/lib/ruby/2.4.0/timeout.rb:103:in `timeout'
/usr/local/lib/ruby/2.4.0/net/http.rb:902:in `connect'
/usr/local/lib/ruby/2.4.0/net/http.rb:887:in `do_start'
/usr/local/lib/ruby/2.4.0/net/http.rb:876:in `start'
/usr/local/lib/ruby/2.4.0/open-uri.rb:323:in `open_http'
/usr/local/lib/ruby/2.4.0/open-uri.rb:741:in `buffer_open'
/usr/local/lib/ruby/2.4.0/open-uri.rb:212:in `block in open_loop'
/usr/local/lib/ruby/2.4.0/open-uri.rb:210:in `catch'
/usr/local/lib/ruby/2.4.0/open-uri.rb:210:in `open_loop'
/usr/local/lib/ruby/2.4.0/open-uri.rb:151:in `open_uri'
/var/www/discourse/lib/freedom_patches/open_uri_redirections.rb:70:in `open_uri'
/usr/local/lib/ruby/2.4.0/open-uri.rb:721:in `open'
/usr/local/lib/ruby/2.4.0/open-uri.rb:35:in `open'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:82:in `fetch_rss'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:68:in `topics'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:27:in `poll_feed'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:16:in `execute'
/var/www/discourse/app/jobs/base.rb:154:in `block (2 levels) in perform'
Env
process_id 10206
current_db default
current_hostname discuss.moe
job Jobs::PollFeed
problem_db default
opts
Another set of error at /logs
What is this site? DNS is not resolving for it
Similar problem here (in an almost new community), in a Docker-based installation, sidekiq is restarted frequently (in previous discourse version and latest one, v1.9.0.beta2 +83), here the log/backtrace:
Message
Sidekiq is consuming too much memory (using: 518.18M) for 'community.aseprite.org', restarting
Backtrace
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.7/lib/logster/logger.rb:93:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.7/lib/logster/logger.rb:50:in `add'
/usr/local/lib/ruby/2.4.0/logger.rb:534:in `warn'
config/unicorn.conf.rb:167:in `check_sidekiq_heartbeat'
config/unicorn.conf.rb:190:in `master_sleep'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:294:in `join'
Env
hostname community-1-app
process_id 1500
application_version 48fb19d9e483bc118c007eef1a997d5126e3adfc
I have 9 similar errors since 17 Jun 2:59 pm
it was a ghost blog engine, which i removed and it discourse was embedded as a commenting platform.
I have removed it from the embed setting but it still shows this error.
Remember that this message is only updated by an occasionally running Sidekiq job, so it may take some time to update even after Sidekiq is started ![]()
