Signup button while on mobiles
Hi,
When we access a discourse forum from a mobile device, the “signup” button is nowhere to be seen, though the login button is.
Is there a way we can add a signup button for mobile devices too?
Thanks.
Does Login > Create New Account not work?
ah, i should have mentioned that on my message. Though that does work, but most people might not even consider that.
It’s much better to have a direct button/link on upfront.
Feel free to override the text on the button to whatever you prefer in Admin, Customize, Text.
…is there a way we can make this modification visible only on mobiles? Else it’ll look like “signup” and “signup/login” on a computer :no_mouth:
… anyone else who can think of a solution?
You could override the text and hide the sign up button even on desktop.
I went to Admin, Customize, Text… i typed “log in”. Following are the options i get, and none of them reflect the change.
…sorry for the super rocket-science question, but which one from the list is the correct on for the “log in” button on the nav bar… i tried all but none of them work.
don’t know which one is the answer! since mine doesn’t change either, but know that sometimes for the text to be customized after the changes, i had to run the launcher rebuild app, because of the cashing issue.
