Masacote
                    September 12, 2021,  2:44am
                  1
              Hello everyone, everything good ?
I just did an installation of discourse and I have two rather simple situations
1- How do I edit the welcome message at the Top of Discouse
2- My forum starts automatically in DARK mode, how do I start it in primary LIGHT mode and secondary DARK mode.
Thanks for the answer from anyone who can help
                keegan
                    September 12, 2021,  3:30am
It looks like you have the Search banner  theme component installed. To change the headline and subhead text navigate to:
Hamburger Icon (top right) -> Settings -> Customize -> Components -> discourse-search-banner
Below the theme settings there should be two input fields underneath ‘Theme Translations’, which you can enter both the heading and subheading there.
If you want to change it only for your specific user:
Profile Icon (top right)
User icon
Preferences
Interface
Switch Theme to ‘Light’
If you want to change it for all users:
Hamburger Icon
Admin Settings
Customize
Change theme from Light to Dark (select Theme is enabled by default)
Note, you may have automatic dark mode switching enabled, in which it will depend on your computer’s selected theme.
                system
                    October 28, 2021, 11:13pm
                  3
