Hello,
On the latest version, when I try and add a site, it doesn’t add.
Same thing happens when you are http or https.
Hello,
<link rel="canonical" href="http://preloadservice.darkpixlz.com/" />
Your site has https
enabled. But the canonical
tag doesn’t have https
in the URL. It may be related to the issue.
How can I change it to have https? I was told force_https will break the site because of my current ssl config
How is your SSL configured?
If you’re using HTTPS then force_https
isn’t optional. You need to fix your SSL encapsulation if it’s not compatible with force_https.
That’s just what I was told. I’ll enable force_https right now and just disable it from the rails console if it breaks something
You were told that by someone here on meta?
Correction: Cloudflare seems to have picked up on it and SSL is working fully and the site is working.
Still not letting me add it. I’d record it if I could but it says my real address when I try and type it in
