Site becomes blank after update due to topic list plugin
Hello,
I updated yesterday my website. The process looked fine but the website is completely blank:
Any help much appreciated.
Hey Richard,
Your site loads just fine in safe mode – Libertysim.net - Simulation aĆ©rienne Forum & Discussions. Can you try to use the options there to figure out what exactly is causing this error?
Uncaught TypeError: route is undefined
    initialize 0349339c1db85f050f5e45323f5c151527728ec0.js:1607
    initialize 0349339c1db85f050f5e45323f5c151527728ec0.js:1605
    initialize _application-2bffcc084608e48944e6dde869ccde3606797fbcb07c2345c84cf88c5f47f9d3.js:6927
    jQuery 21
Hi,
Unfortunately, I cannot reach the GUI to change options. Is there a way to do it by command line on the server ?
I meant you should first figure out the cause of the issue by visting the safe mode link which will load: https://libertysim.net/safe-mode.
As always, a good first bet is to remove all unofficial plugins from your app.yml and rebuild the site.
OK. Got it. Something is wrong with unofficial plugin topic list previews. So I inactivate it
Thank you for your help
i have the same problem also with the unofficial plugin ā€œtopic list previewsā€ anyone a solution? thanks.
Hey everyone,
@merefield has pushed a fix at Topic List Previews and rebuilding should bring the site back. If you still have problems, feel free to bring it up on that topic.
