Heeeelp, leere Webseite nach dem Neuaufbau
Hi,
So some days ago I was asking about issues I had with private messages.
Apparently, the problem was that I was using a broken plugin called Quick Message.
So I just decided to remove it (by editing app.yml and deleting the line) and rebuild again.
But when it was finished and tried to come back on the forum, I can only see my background on the page and nothing else.
I’d really appreciate if someone could help me fix this :sweat:
Check out this thread
4 „Gefällt mir“
I’ve disabled the Topic List Previews (legacy) plug-in.
And logged a bug report
2 „Gefällt mir“
Thanks a lot @donnay1 ! :pray:
I’ll disable it and rebuild and tell here if it fixed the issue.
1 „Gefällt mir“
I didn’t even have to rebuild. Just disable the plugin and voila
1 „Gefällt mir“
It worked, thanks! :slight_smile:
Thanks for reporting it on the Pavilion website.
The issue with Topic List Previews should be fixed as of COMPATIBILITY: remove deprecated routes · merefield/discourse-topic-previews-sidecar@971ba5d · GitHub
Please take note of the supported period for upgrades.
I have upgraded to the latest commit of the plug-in and am happy to report the site is functioning as expected. Thank you for your prompt response! :smiling_face_with_three_hearts:
1 „Gefällt mir“
