בעיית כותרת אתר בעת שינוי גודל
Hello,
When I resize the site i get some errors.
The error is visually appears on the popup search width (less wide than normal).
Probably related with this recent commit: FEATURE: sidebar for narrow desktop screen (#19160) · discourse/discourse@5b6604f · GitHub
Repro:
  1. resize the window under 1100px
  2. increase the window back to over 1100px
  3. open the user menu or search and check the console
Thank you :slightly_smiling_face:
3 לייקים
I can reproduce this on meta, but the same doesn’t happens on my local. In my local I am on latest main branch DEV: removes select-kit deprecation (#19200) · discourse/discourse@b032115 · GitHub
2 לייקים
Thanks for the report, we have identified the issue and will try to come up with the fix this week.
4 לייקים
Thank you @Don for reporting this issue. It should be already fixed :slight_smile:
5 לייקים
