Hi,
I am doing a self hosted Discourse (a contractor installed it) and updating to the latest beta (via the auto-update) today it said there was an error during update and it all stopped working. Site is offline.
What shall I do ?
Hi,
What shall I do ?
I’m tried this and does’t works
if you have an snapshot do it and wait until be fixed.
Thanks for the reply. Where do I enter “./launcher rebuild app” ?
SSH
cd ..
cd var/discourse
Thanks, but I get stuff like
UPGRADE OF POSTGRES FAILED
Please visit https://meta.discourse.org/t/postgresql-15-update/349515 for support.
You can run ./launcher start app to restart your app in the meanwhile
FAILED
Pups::ExecError: if [ -f /root/install_postgres ]; then
/root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
failed with return #<Process::Status: pid 18 exit 1>
exec failed with the params {"tag"=>"db", "cmd"=>"if [ -f /root/install_postgres ]; then\n /root/install_postgres && rm -f /root/install_postgres\nelif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then\n socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1\nfi\n"}
c5b5958a65b830ae97f279c6df70e8b485b2d9d594af68767a953ff59e6ca286
Exactly what I said, use snap to restore old container and wait this be fixed I tried update too and my web server don’t start for some reason.
Thanks for trying to help. I have no time for this. Going back to a static Hugo site. Bye Discourse.
I would advise you to post in the topic mentioned.
Discourse just needs a little patience, and it’ll work.
Yup, please do follow the debugging steps in that topic, and let us know if you have any more info @eisammy @Markus_Moenig
We don’t have any fixes waiting for release. So if stuff is still not working for you, we need more information to help.
What I don’t understand is why you invest a lot of work to create a noob proof easy to use UI to attract web-tech noobs like me and than put potentially hazardous updates in there without any warning.
I rage destroyed my droplet after trying to get it to work for 4 hours today. So there is no way back for me.
Absolute correct! I did this now and my instance was updated and is running normally thank you.
And @Markus_Moenig , this tutorial it’s enough to solve this trouble
Glad to hear it’s working @eisammy
@Markus_Moenig I’m sorry things didn’t work out. We do our best to keep these kinds updates as seamless as possible, but sometimes things do go wrong. I agree that can be frustrating. We do our best to be as responsive as possible here on Meta, but I understand that’s not always enough.
I’m going to close out this topic. But if you or anyone else has any related issues please feel free to open a fresh one in Support.
