最新更新出现问题
I’m having trouble with the latest update. Now my Discourse site is down and will not get up :frowning:
After updating via the admin I was prompted to rebuild the app via the commandline. I did ./launcher rebuild app and it finished successfully. I.e., I got to this:
To complete the upgrade, rebuild again using:
I dutifully did so, but ended up with the same message. I tried it a couple more times, before I decided that something was definitely up.
The site was down at this point so I tried to bring it back up with ./launcher start app.
The site will not come up and I’m getting a “502 Bad Gateway” message.
Any suggestions? :sweat_smile:
(Edited for clarity.)
Try going through this topic to see if you’ll find something similar to your case:
2 个赞
I had looked through that thread @osioke but had been afraid to tinker further, without getting a clearer picture of what’s going on.
I was able to bring my site back by reverting "templates/postgres.template.yml" to "templates/postgres.10.template.yml" in app.yml.
It wasn’t clear from the instructions there that this could be used after running the update – only that it could be used to postpone it.
2 个赞
