Problem with upgrading the latest version
Hi, I am trying to update Discourse to the latest version.
FAILED
Pups::ExecError: /root/upgrade_postgres failed with return #<Process::Status: pid 45 exit 1>
exec failed with the params "/root/upgrade_postgres"
1cafe54cd6661316d8e9e393c54f73ab89bc3f5e70e104f6c5e4f8794053c09c
Also
 Success. You can now start the database server using:
    pg_ctlcluster 10 main start
Warning: The selected stats_temp_directory /var/run/postgresql/10-main.pg_stat_tmp
is not writable for the cluster owner. Not adding this setting in
postgresql.conf.
Ver Cluster Port Status Owner    Data directory              Log file
10  main    5433 down   postgres /var/lib/postgresql/10/main /var/log/postgresql/postgresql-10-main.log
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/12/man/man1/postmaster.1.gz because link group postmaster.1.gz is broken
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Processing triggers for postgresql-common (213.pgdg100+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
Stopping PostgreSQL 10 database server: main.
Stopping PostgreSQL 12 database server: main.
Performing Consistency Checks
Checking cluster versions                                   ok
The source cluster was not shut down cleanly.
Failure, exiting
Output of tail -f shared/standalone/log/var-log/postgres/current command:
2020-06-14 01:37:02.155 UTC [3508] FATAL:  data directory "/shared/postgres_data" has wrong ownership
2020-06-14 01:37:02.155 UTC [3508] HINT:  The server must be started by the user that owns the data directory.
Postponing the update
If you need to postpone the update during your next rebuild, you can swap the PostgreSQL template on your app.yml file by changing "templates/postgres.template.yml" to "templates/postgres.10.template.yml" .
This is not recommended, as some site admins will forget to revert the change afterwards.
I applied this and the Discourse forum is now online. What can we do next? Currently, I am using “templates/postgres.10.template.yml”
Any ideas? I am still using “templates/postgres.10.template.yml".
Try the following:
  1. Edit the app.yml and change "templates/postgres.10.template.yml" to "templates/postgres.template.yml" .
  2. Issue a stop: ./launcher stop app
  3. Try a rebuild ./launcher rebuild app
Upgrade Complete
Optimizer statistics are not transferred by pg_upgrade so,
once you start the new server, consider running:
    ./analyze_new_cluster.sh
Running this script will delete the old cluster's data files:
    ./delete_old_cluster.sh
UPGRADE OF POSTGRES COMPLETE
Old 10 database is stored at /shared/postgres_data_old
To complete the upgrade, rebuild again using:
And Discourse forum offline at this time.
I am trying ./launcher rebuild app again as said above.
Yes that is expected.
Yeah, follow the instructions and it should be back soon.
Interesting and awesome, now the update has been successfully completed. I have tried the same way many times before, but it never happened.
Do I need to use the following commands to clear the space?
Thank you!
You can run the Post update optional tasks listed in our FAQ.
Wonderful. Thanks again!
