Banco de dados pequeno, talvez um tema e alguns plugins:
- https://github.com/discourse/docker_manager.git
- https://github.com/discourse/discourse-openid-connect.git
- https://github.com/discourse/discourse-math.git
- https://github.com/discourse/discourse-spoiler-alert
- https://github.com/discourse/discourse-solved.git
- https://github.com/discourse/discourse-chat-integration.git
Vou reconstruí-lo manualmente e verificar quanto tempo leva.
Aqui está parte do log:
aliens@forum:/var/discourse$ time sudo ./launcher rebuild app
real 22m27.712s
user 0m2.069s
sys 0m1.470s
I, [2021-02-12T14:12:45.955900 #1] INFO -- : Carregando --stdin
I, [2021-02-12T14:12:45.962212 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2021-02-12T14:12:46.633275 #1] INFO -- : Gerando localidades (isso pode demorar um pouco)...
I, [2021-02-12T14:12:46.633768 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2021-02-12T14:12:46.637076 #1] INFO -- :
I, [2021-02-12T14:12:46.637442 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-02-12T14:12:46.640032 #1] INFO -- :
I, [2021-02-12T14:12:46.640326 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2021-02-12T14:12:46.642547 #1] INFO -- :
I, [2021-02-12T14:12:46.642869 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2021-02-12T14:12:46.645856 #1] INFO -- :
I, [2021-02-12T14:12:46.646137 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-02-12T14:12:46.666510 #1] INFO -- :
I, [2021-02-12T14:12:46.666914 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres já está em execução, pare o container ; exit 1
I, [2021-02-12T14:12:47.168264 #1] INFO -- :
I, [2021-02-12T14:12:47.168523 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-02-12T14:12:47.172123 #1] INFO -- :
I, [2021-02-12T14:12:47.172331 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-02-12T14:12:47.175386 #1] INFO -- :
I, [2021-02-12T14:12:47.175693 #1] INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-02-12T14:12:47.178473 #1] INFO -- :
I, [2021-02-12T14:12:47.178875 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-02-12T14:12:47.181231 #1] INFO -- :
I, [2021-02-12T14:12:47.187254 #1] INFO -- : Arquivo > /etc/service/postgres/run chmod: +x chown:
I, [2021-02-12T14:12:47.192927 #1] INFO -- : Arquivo > /etc/service/postgres/log/run chmod: +x chown:
I, [2021-02-12T14:12:47.198897 #1] INFO -- : Arquivo > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2021-02-12T14:12:47.204663 #1] INFO -- : Arquivo > /root/upgrade_postgres chmod: +x chown:
I, [2021-02-12T14:12:47.205062 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-02-12T14:15:21.256384 #1] INFO -- :
I, [2021-02-12T14:15:21.257009 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-02-12T14:15:21.259981 #1] INFO -- :
I, [2021-02-12T14:15:21.260154 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-02-12T14:15:21.948040 #1] INFO -- :
I, [2021-02-12T14:15:21.948552 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-02-12T14:15:21.951704 #1] INFO -- :
I, [2021-02-12T14:15:21.952027 #1] INFO -- : > /root/upgrade_postgres
I, [2021-02-12T14:15:21.975184 #1] INFO -- :
I, [2021-02-12T14:15:21.975342 #1] INFO -- : > rm /root/upgrade_postgres
I, [2021-02-12T14:15:21.977953 #1] INFO -- :
I, [2021-02-12T14:15:22.013157 #1] INFO -- : Substituindo data_directory = '/var/lib/postgresql/13/main' por data_directory = '/shared/postgres_data' em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:22.014186 #1] INFO -- : Substituindo (?-mix:#?listen_addresses *=.*) por listen_addresses = '*' em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:24.436709 #1] INFO -- : Substituindo (?-mix:#?synchronous_commit *=.*) por synchronous_commit = $db_synchronous_commit em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:24.628433 #1] INFO -- : Substituindo (?-mix:#?shared_buffers *=.*) por shared_buffers = $db_shared_buffers em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:25.159240 #1] INFO -- : Substituindo (?-mix:#?work_mem *=.*) por work_mem = $db_work_mem em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:25.184384 #1] INFO -- : Substituindo (?-mix:#?default_text_search_config *=.*) por default_text_search_config = '$db_default_text_search_config' em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:25.259466 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-02-12T14:15:25.309111 #1] INFO -- :
I, [2021-02-12T14:15:25.309652 #1] INFO -- : Substituindo (?-mix:#?checkpoint_segments *=.*) por checkpoint_segments = $db_checkpoint_segments em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:25.377742 #1] INFO -- : Substituindo (?-mix:#?logging_collector *=.*) por logging_collector = $db_logging_collector em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:25.441337 #1] INFO -- : Substituindo (?-mix:#?log_min_duration_statement *=.*) por log_min_duration_statement = $db_log_min_duration_statement em /etc/postgresql/13/main/postgresql.conf
I, [2021-02-12T14:15:25.552764 #1] INFO -- : Substituindo (?-mix:^#local +replication +postgres +peer$) por local replication postgres peer em /etc/postgresql/13/main/pg_hba.conf
I, [2021-02-12T14:15:25.553289 #1] INFO -- : Substituindo (?-mix:^host.*all.*all.*127.*$) por host all all 0.0.0.0/0 md5 em /etc/postgresql/13/main/pg_hba.conf
I, [2021-02-12T14:15:25.590760 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-02-12T14:15:25.594118 #1] INFO -- : > sleep 5
I, [2021-02-12T14:15:30.597053 #1] INFO -- :
I, [2021-02-12T14:15:30.597375 #1] INFO -- : > su postgres -c 'createdb discourse' || true
I, [2021-02-12T14:15:31.013293 #1] INFO -- :
I, [2021-02-12T14:15:31.013704 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
I, [2021-02-12T14:15:31.160001 #1] INFO -- :
I, [2021-02-12T14:15:31.160404 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-02-12T14:15:31.220487 #1] INFO -- : GRANT
I, [2021-02-12T14:15:31.220749 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-02-12T14:15:31.304366 #1] INFO -- : ALTER SCHEMA
I, [2021-02-12T14:15:31.304675 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
I, [2021-02-12T14:15:31.402388 #1] INFO -- : CREATE EXTENSION
I, [2021-02-12T14:15:31.402649 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
I, [2021-02-12T14:15:31.463813 #1] INFO -- : CREATE EXTENSION
I, [2021-02-12T14:15:31.464222 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2021-02-12T14:15:31.560706 #1] INFO -- : CREATE EXTENSION
I, [2021-02-12T14:15:31.560939 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2021-02-12T14:15:31.624479 #1] INFO -- : CREATE EXTENSION
I, [2021-02-12T14:15:31.624979 #1] INFO -- : > sudo -u postgres psql discourse
I, [2021-02-12T14:15:32.086935 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2021-02-12T14:15:32.265765 #1] INFO -- : Arquivo > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2021-02-12T14:15:32.268912 #1] INFO -- : Arquivo > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2021-02-12T14:15:32.269014 #1] INFO -- : > echo postgres instalado!
I, [2021-02-12T14:15:32.271341 #1] INFO -- : postgres instalado!
I, [2021-02-12T14:15:32.277041 #1] INFO -- : Arquivo > /etc/service/redis/run chmod: +x chown:
I, [2021-02-12T14:15:32.282518 #1] INFO -- : Arquivo > /etc/service/redis/log/run chmod: +x chown:
I, [2021-02-12T14:15:32.287789 #1] INFO -- : Arquivo > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2021-02-12T14:15:32.311455 #1] INFO -- : Substituindo daemonize yes por em /etc/redis/redis.conf
I, [2021-02-12T14:15:32.312156 #1] INFO -- : Substituindo (?-mix:^pidfile.*$) por em /etc/redis/redis.conf
I, [2021-02-12T14:15:33.185632 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2021-02-12T14:15:33.189667 #1] INFO -- :
I, [2021-02-12T14:15:33.190303 #1] INFO -- : Substituindo (?-mix:^logfile.*$) por logfile "" em /etc/redis/redis.conf
I, [2021-02-12T14:15:33.248320 #1] INFO -- : Substituindo (?-mix:^bind .*$) por em /etc/redis/redis.conf
I, [2021-02-12T14:15:33.280622 #1] INFO -- : Substituindo (?-mix:^dir .*$) por dir /shared/redis_data em /etc/redis/redis.conf
I, [2021-02-12T14:15:33.316107 #1] INFO -- : Substituindo (?-mix:^protected-mode yes) por protected-mode no em /etc/redis/redis.conf
I, [2021-02-12T14:15:33.371939 #1] INFO -- : Substituindo # io-threads 4 por io-threads $redis_io_threads em /etc/redis/redis.conf
I, [2021-02-12T14:15:33.380946 #1] INFO -- : > echo redis instalado
I, [2021-02-12T14:15:33.383880 #1] INFO -- : redis instalado
I, [2021-02-12T14:15:33.384290 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2021-02-12T14:15:33.388772 #1] INFO -- : logfile ""
I, [2021-02-12T14:15:33.389071 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-02-12T14:15:33.390851 #1] INFO -- : > sleep 10
I, [2021-02-12T14:15:43.393519 #1] INFO -- :
I, [2021-02-12T14:15:43.394261 #1] INFO -- : > thpoff echo "thpoff está instalado!"
I, [2021-02-12T14:15:43.398396 #1] INFO -- : thpoff está instalado!
I, [2021-02-12T14:15:43.398644 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Abortando! E-mail não está configurado!"; exit 1; end'
I, [2021-02-12T14:15:43.482669 #1] INFO -- :
I, [2021-02-12T14:15:43.483047 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Abortando! Domínio não está configurado!"; exit 1; end'
I, [2021-02-12T14:15:43.558655 #1] INFO -- :
I, [2021-02-12T14:15:43.558943 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Abortando! O CDN deve ter um protocolo especificado. Uma vez corrigido, você deve refazer o bake das suas publicações agora para corrigir todas as publicações."; exit 1; end'
I, [2021-02-12T14:15:43.641372 #1] INFO -- :
I, [2021-02-12T14:15:43.641677 #1] INFO -- : > chown -R discourse /home/discourse
I, [2021-02-12T14:16:45.838187 #1] INFO -- :
I, [2021-02-12T14:16:45.840385 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2021-02-12T14:16:45.844572 #1] INFO -- :
I, [2021-02-12T14:16:45.850050 #1] INFO -- : Arquivo > /etc/cron.d/anacron chmod: chown:
I, [2021-02-12T14:16:45.855854 #1] INFO -- : Arquivo > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2021-02-12T14:16:45.861277 #1] INFO -- : Arquivo > /etc/service/unicorn/run chmod: +x chown:
I, [2021-02-12T14:16:45.866688 #1] INFO -- : Arquivo > /etc/service/nginx/run chmod: +x chown:
I, [2021-02-12T14:16:45.872249 #1] INFO -- : Arquivo > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2021-02-12T14:16:45.877861 #1] INFO -- : Arquivo > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2021-02-12T14:16:45.878086 #1] INFO -- : Substituindo # postgres por sv start postgres || exit 1 em /etc/service/unicorn/run
I, [2021-02-12T14:16:45.878406 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-02-12T14:16:45.880542 #1] INFO -- : > cd /var/www/discourse && git reset --hard
I, [2021-02-12T14:17:02.926735 #1] INFO -- : HEAD está agora em c4552e9c CORREÇÃO: Vídeos de autoplay devem sempre estar silenciados (#11533)
I, [2021-02-12T14:17:02.927239 #1] INFO -- : > cd /var/www/discourse && git clean -f
I, [2021-02-12T14:17:03.084509 #1] INFO -- :
I, [2021-02-12T14:17:03.084936 #1] INFO -- : > cd /var/www/discourse && git remote set-branches --add origin master
I, [2021-02-12T14:17:03.089849 #1] INFO -- :
I, [2021-02-12T14:17:03.090120 #1] INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2021-02-12T14:17:03.124282 #1] INFO -- :
I, [2021-02-12T14:17:03.124588 #1] INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
I, [2021-02-12T14:17:08.243029 #1] INFO -- :
I, [2021-02-12T14:17:08.243186 #1] INFO -- : > cd /var/www/discourse && git checkout tests-passed
I, [2021-02-12T14:17:09.184686 #1] INFO -- : Branch 'tests-passed' configurado para rastrear o branch remoto 'tests-passed' de 'origin'.
I, [2021-02-12T14:17:09.185043 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2021-02-12T14:17:09.189503 #1] INFO -- :
I, [2021-02-12T14:17:09.189934 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2021-02-12T14:17:09.233988 #1] INFO -- :
I, [2021-02-12T14:17:09.234524 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2021-02-12T14:17:09.239129 #1] INFO -- :
I, [2021-02-12T14:17:09.239356 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2021-02-12T14:17:09.243412 #1] INFO -- :
I, [2021-02-12T14:17:09.243668 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2021-02-12T14:17:09.247268 #1] INFO -- :
I, [2021-02-12T14:17:09.247491 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2021-02-12T14:17:09.251701 #1] INFO -- :
I, [2021-02-12T14:17:09.251901 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2021-02-12T14:17:09.257343 #1] INFO -- :
I, [2021-02-12T14:17:09.257528 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2021-02-12T14:17:09.262945 #1] INFO -- :
I, [2021-02-12T14:17:09.263138 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2021-02-12T14:17:09.268702 #1] INFO -- :
I, [2021-02-12T14:17:09.269124 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2021-02-12T14:17:09.274278 #1] INFO -- :
I, [2021-02-12T14:17:09.274482 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2021-02-12T14:17:09.279930 #1] INFO -- :
I, [2021-02-12T14:17:09.280139 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2021-02-12T14:17:09.285209 #1] INFO -- :
I, [2021-02-12T14:17:09.285457 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2021-02-12T14:17:09.396237 #1] INFO -- :
I, [2021-02-12T14:17:09.396669 #1] INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2021-02-12T14:17:09.435442 #1] INFO -- :
I, [2021-02-12T14:17:09.436219 #1] INFO -- : Substituindo # redis por sv start redis || exit 1 em /etc/service/unicorn/run
I, [2021-02-12T14:17:09.436996 #1] INFO -- : > cd /var/www/discourse/app && sed -i "s/input value=accountUsername/input value=accountUsername disabled=true/" assets/javascripts/discourse/app/templates/modal/create-account.hbs
I, [2021-02-12T14:17:09.478457 #1] INFO -- :
I, [2021-02-12T14:17:09.479245 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
I, [2021-02-12T14:17:19.949506 #1] INFO -- :
I, [2021-02-12T14:17:19.949666 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-openid-connect.git
I, [2021-02-12T14:17:22.456981 #1] INFO -- :
I, [2021-02-12T14:17:22.457375 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-math.git
I, [2021-02-12T14:17:28.640267 #1] INFO -- :
I, [2021-02-12T14:17:28.640409 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-spoiler-alert
I, [2021-02-12T14:17:34.135485 #1] INFO -- :
I, [2021-02-12T14:17:34.135603 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
I, [2021-02-12T14:17:42.135436 #1] INFO -- :
I, [2021-02-12T14:17:42.135862 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-chat-integration.git
I, [2021-02-12T14:17:46.531573 #1] INFO -- :
I, [2021-02-12T14:17:46.532107 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2021-02-12T14:17:46.574768 #1] INFO -- :
I, [2021-02-12T14:17:46.575449 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2021-02-12T14:17:46.578367 #1] INFO -- :
I, [2021-02-12T14:17:46.578696 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2021-02-12T14:17:46.581540 #1] INFO -- :
I, [2021-02-12T14:17:46.586431 #1] INFO -- : Substituindo pid /run/nginx.pid; por daemon off; em /etc/nginx/nginx.conf
I, [2021-02-12T14:17:46.587071 #1] INFO -- : Substituindo (?m-ix:upstream[^\}]+\}) por upstream discourse { server 127.0.0.1:3000; } em /etc/nginx/conf.d/discourse.conf
I, [2021-02-12T14:17:46.587476 #1] INFO -- : Substituindo (?-mix:server_name.+$) por server_name _ ; em /etc/nginx/conf.d/discourse.conf
I, [2021-02-12T14:17:46.603447 #1] INFO -- : Substituindo (?-mix:client_max_body_size.+$) por client_max_body_size $upload_size ; em /etc/nginx/conf.d/discourse.conf
I, [2021-02-12T14:17:46.679624 #1] INFO -- : > echo "configuração da web concluída"
I, [2021-02-12T14:17:46.682047 #1] INFO -- : configuração da web concluída
I, [2021-02-12T14:17:46.682561 #1] INFO -- : > cd /var/www/discourse && gem update bundler
I, [2021-02-12T14:17:53.098565 #1] INFO -- : Atualizando gems instaladas
I, [2021-02-12T14:17:53.098690 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2021-02-12T14:22:54.825495 #1] INFO -- :
I, [2021-02-12T14:22:54.826652 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
I, [2021-02-12T14:24:47.161455 #1] INFO -- : Executando `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` com o bundler 2.2.9
I, [2021-02-12T14:24:47.162270 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-02-12T14:25:19.993529 #1] INFO -- : discourse-spoiler-alert já está na versão compatível mais recente
I, [2021-02-12T14:25:19.994069 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2021-02-12T14:25:59.683204 #1] INFO -- :
I, [2021-02-12T14:25:59.683442 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
I, [2021-02-12T14:26:04.560560 #4880] INFO -- : Gravando /var/www/discourse/public/assets/vendor-cbd6e0773a348bdfe5771d26f9eb195929c0b36a2c09bdca0b903edd080428bc.js
I, [2021-02-12T14:26:12.841565 #4880] INFO -- : Gravando /var/www/discourse/public/assets/admin-9b518093f4c20ef95f264bc28e10318110e8741afad865dbf76a424d69d28ccc.js
I, [2021-02-12T14:26:12.847920 #4880] INFO -- : Gravando /var/www/discourse/public/assets/browser-detect-115ab5953de1b5bb122bfb26b757f5391dd8d1d2aef2b81baf7b59aee99d9f34.js
I, [2021-02-12T14:26:12.851936 #4880] INFO -- : Gravando /var/www/discourse/public/assets/browser-update-92cd9b3599f62ca785b6cbf3d8d3afb080d6cd463034e2fccefd5455b0f5fff6.js
I, [2021-02-12T14:26:12.855958 #4880] INFO -- : Gravando /var/www/discourse/public/assets/break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js
I, [2021-02-12T14:26:19.583102 #4880] INFO -- : Gravando /var/www/discourse/public/assets/ember_jquery-36a23101c869ab0dc53fc908de69adb785731593573d32bdeef416acc1076ef4.js
I, [2021-02-12T14:26:20.759892 #4880] INFO -- : Gravando /var/www/discourse/public/assets/pretty-text-bundle-f07dfa9b2ec7ca83cf749b3959b4ca595f90fecb33c6793a6eecad166fee7bf7.js
I, [2021-02-12T14:26:23.608879 #4880] INFO -- : Gravando /var/www/discourse/public/assets/wizard-application-bacd9e817bd7491e1d278d8511370f86b9a6bcf91cee3ad039b3b2f3a116d474.js
I, [2021-02-12T14:26:23.660357 #4880] INFO -- : Gravando /var/www/discourse/public/assets/wizard-vendor-9a4c01e35fad22133b0dc5896b2bd1fde538bc03f51828485c8598ec260f3936.js
I, [2021-02-12T14:26:24.204929 #4880] INFO -- : Gravando /var/www/discourse/public/assets/markdown-it-bundle-04999a8c1ce5e0e2544244cf2303c4383d8aaae90f8446b875a9724470a9aca3.js
I, [2021-02-12T14:26:24.213263 #4880] INFO -- : Gravando /var/www/discourse/public/assets/service-worker-c05179ef4f55c98f86ca3a3fc55a80e84994fc0400de1de7748481441e8c973a.js
I, [2021-02-12T14:26:24.233191 #4880] INFO -- : Gravando /var/www/discourse/public/assets/google-tag-manager-fa22e2f6e90054a789e680fd7c9357cb322d817c193d4a71af296db9dfe3e26e.js
I, [2021-02-12T14:26:24.241857 #4880] INFO -- : Gravando /var/www/discourse/public/assets/google-universal-analytics-v3-706f1d28f0a97f67a47515c96189277240ec4940d968955042066d7873fd1fe8.js
I, [2021-02-12T14:26:24.249514 #4880] INFO -- : Gravando /var/www/discourse/public/assets/google-universal-analytics-v4-3f290b57b4e029da9e59f074043a0c8e816f099ef4ccffe82b821ff43e9a4c7f.js
I, [2021-02-12T14:26:24.255874 #4880] INFO -- : Gravando /var/www/discourse/public/assets/start-discourse-efa4e5abfbd1b50b5152ffbe64d5dcea9f7c33f766dcc6387e2711f0f2112148.js
I, [2021-02-12T14:26:24.259925 #4880] INFO -- : Gravando /var/www/discourse/public/assets/print-page-e36056a4075e3fd3032cbf30b45aa1ce743abe55bf79f9e92429f33446f0801b.js
I, [2021-02-12T14:26:24.271846 #4880] INFO -- : Gravando /var/www/discourse/public/assets/activate-account-a1f1c2df02186f5182c09abcba45827d0284071678fabffc91ef23b17add35bb.js
I, [2021-02-12T14:26:24.281874 #4880] INFO -- : Gravando /var/www/discourse/public/assets/auto-redirect-4629c3e3258ec7a5a9aafe3dc77db2bdaa15db2ac68275e549bdb0e708643e34.js
I, [2021-02-12T14:26:24.289439 #4880] INFO -- : Gravando /var/www/discourse/public/assets/wizard-start-f142a86a7c6379e363875dc55b832b2c0ecd6d59c391af4c9d00ff34e41f9ed0.js
I, [2021-02-12T14:26:24.295276 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/i18n-ea49fc7729180d7e43506b7ca9377c9129ebbcf1c61060c4e1f5fdaf86c92bdd.js
I, [2021-02-12T14:26:24.322373 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse/app/lib/webauthn-af17e0b522e5257259b9c2c0184e981c801abe039c011748207076c40ab52d72.js
I, [2021-02-12T14:26:24.337606 #4880] INFO -- : Gravando /var/www/discourse/public/assets/confirm-new-email/confirm-new-email-35282b052451b4a25beca1667e4cf7ce022121f8d2107a078251a042e9c38419.js
I, [2021-02-12T14:26:24.347765 #4880] INFO -- : Gravando /var/www/discourse/public/assets/confirm-new-email/bootstrap-52b6b6b3fa62d64b09775e2803255326bef3a94a16063a8c191a37e0909f59d1.js
I, [2021-02-12T14:26:24.358913 #4880] INFO -- : Gravando /var/www/discourse/public/assets/onpopstate-handler-417528e7d5f1058afdf6002e7606a3f51c2abc04573b72c85a24374a343448f2.js
I, [2021-02-12T14:26:24.373582 #4880] INFO -- : Gravando /var/www/discourse/public/assets/embed-application-9cef8308c816fc1d83137e63d6c556c6cc2b68fe2b6e5ce16cca6766ba2c0ae4.js
I, [2021-02-12T14:26:24.614865 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/en-20da23b402709f304c044bb48d1526ec7209d0b78680e7e15778cbe1e16e1b7c.js
I, [2021-02-12T14:26:24.897846 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/zh_TW-1c69366e34fd9f5da19231eeb4e5c7a726d991bd39982be4574ddc98484da539.js
I, [2021-02-12T14:26:25.097500 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/et-d45401d4ffa5f3b2af0c15baee2335b7b872801a31211d8dc7defdbd535e91ca.js
I, [2021-02-12T14:26:25.371642 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/he-7df2aa3d2858820c59456098e50843d524ce08077afebd14fd3554f61f6b9862.js
I, [2021-02-12T14:26:25.608644 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/de-2201ed74f2cc8283f203d9ac3e75d25b4249d11274c1ef4798d5651d30288f7a.js
I, [2021-02-12T14:26:25.810520 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/da-c1afeed3143ff90d44caaad578167348854de6a0ad2ed720b0e3a1f01b77056b.js
I, [2021-02-12T14:26:25.996483 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/sk-18299d6d2734755f43e203f78da8667fd44e7d3f743d1fae6e42454840c97ba8.js
I, [2021-02-12T14:26:26.228985 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/sv-3965bf11b720e2b8c3e24d2b7f9d57a4ad7b5e8d7becdb419b3009b2cbda5ec5.js
I, [2021-02-12T14:26:26.441453 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/fi-b58320fff56953f6cf26e71d509b10a4479e43ccc455ed2c33e61f4ffdd7c6ac.js
I, [2021-02-12T14:26:26.629819 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/lt-9b0f5015bb99dd73d26cc262a4fa50089dc547a308484f16e63048e78909f82a.js
I, [2021-02-12T14:26:26.835676 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/nb_NO-c765263283aad4b6d537b420e125108388928d4263f40dbca28e0d9d96105033.js
I, [2021-02-12T14:26:27.043397 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/pt_BR-d1740a9fe5f812742d71ac8ba5d613463a862f9eee80f1c549af39b8ce0bfe0a.js
I, [2021-02-12T14:26:27.240127 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/pt-14a64a296ab17b392a90248f6f07c6389c85b1bee1191b303053cebcaa888e56.js
I, [2021-02-12T14:26:27.457280 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/cs-42a32eb8bf11a877a3c644add58daa6f900fd101332126864ee4afdc4b80061b.js
I, [2021-02-12T14:26:27.766077 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/it-b5f10a9d89b846ce99b9ab1a8da9e336944493e34713e7f8826b87e2f2cf1911.js
I, [2021-02-12T14:26:28.482575 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/th-d9163c19536523928579bade16336ad99aca4f8dff332b57d281f811d5a5e16e.js
I, [2021-02-12T14:26:28.733516 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/ro-be981f3f9fb1961c3c64588faac14804f60664f19e7ef9ef3baef4cbd218ee3f.js
I, [2021-02-12T14:26:28.920613 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/sq-52409d5632388e2fa23616ffccd182ba6fb23a84ad0823c7bd02ae897eb90eb5.js
I, [2021-02-12T14:26:29.177666 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/ar-b12c0be791a6642df69803c1c486540d87eab64bc0536bc1ec50818f01641e89.js
I, [2021-02-12T14:26:29.421417 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/fa_IR-dcb32ab59d1da09c5f977bff795bfecc272704554560107d441a4d2a89cb6ff8.js
I, [2021-02-12T14:26:29.619720 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/te-0768f34951cbc0597301cac514bf81de1e0c005fdc2ff5e1a9419411c4e5116d.js
I, [2021-02-12T14:26:29.834450 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/ur-fe8a89865a0208912ff99912cfe21bdae91a8adbc700a9fe970a06c9efbdf9a1.js
I, [2021-02-12T14:26:30.047313 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/bs_BA-7704878b63f43f12c3a27842ab2d47adea30cfb7a8ce904d25376db57d83d720.js
I, [2021-02-12T14:26:30.252620 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/es-784711aac09356e57d3733d17896462d9c40fff031219fd718e7803330fe8dbe.js
I, [2021-02-12T14:26:30.487958 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/el-8641de917992b34ee34681702a3bc80a224c0f532fa37bd3c5e61b5d1dfd2340.js
I, [2021-02-12T14:26:30.673178 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/id-2a4d901a1f32a915cee6bfa1189bd2845aa5c68eaa4580b094b7cff0ae3775ab.js
I, [2021-02-12T14:26:30.888713 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/nl-ee34dab800d700bc32a806da1662cc16bf56004e9875b5c32c08a18d81922224.js
I, [2021-02-12T14:26:31.207112 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/fr-e827308400f67a788b7e717b4d6213c7ff896b5aeca51b167df9be7862ac3f30.js
I, [2021-02-12T14:26:31.528660 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/ru-08adc2653eaa49cab733aaa6854ee93ca2c7fa971143d9e052251a5891bb8de0.js
I, [2021-02-12T14:26:31.776351 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/uk-f821c8dc163dd23ed01e9e39cb4fee406ef726b5abca8fc4ab1c8d52889c433c.js
I, [2021-02-12T14:26:31.979736 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/zh_CN-44df73efd38f81addd66ba60c73b21562fe5d98a7cdba799a65c8ff15b98f714.js
I, [2021-02-12T14:26:32.178912 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/ja-5b38b3748434220f8f3c3e3b29ca7d183fe323eaeffc05c13066e50d588d5185.js
I, [2021-02-12T14:26:32.361794 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/lv-3cf532ea9df4501c0b1e22b5889d5e1fbcb37a4e99b337e12cfc18364e405c61.js
I, [2021-02-12T14:26:32.564658 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/tr_TR-9d40b21e147b2b0df91cf1ca5b43a41a7931554ed7a36e64c9ab44019e4d1470.js
I, [2021-02-12T14:26:32.789210 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/pl_PL-d14596b55e67ae1e55e53d7d67661ce89bfbaea1f79a00ccd0e505bb034e0485.js
I, [2021-02-12T14:26:32.982027 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/hu-fb69991d2236877503444bf48d283c3aaed09d3d236c8b1a107bc65fe80980f2.js
I, [2021-02-12T14:26:33.244588 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/bg-ca03268f3575636c0ed5a05a5bb44324bef82872e57918b861c2babd33b75733.js
I, [2021-02-12T14:26:33.443152 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/sl-8a83b6b3e9697b9bb1bdaa05f12e928dc1b4d7bb504bcfb5cf127bc0a5cd5f9d.js
I, [2021-02-12T14:26:33.661673 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/gl-72ff8659006c8eda7a3562e45045bbf5ac4cf69e9132b2269277cd78499b36e8.js
I, [2021-02-12T14:26:33.913591 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/sw-cb374ffb9122f97c564c913bc02f743bc77081729c7927da794c616e16e620a9.js
I, [2021-02-12T14:26:34.255245 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/vi-50058b2c18cec141c7cbc1e6c4b08982e6a9991727add207fa6f804ebe813d2b.js
I, [2021-02-12T14:26:34.505375 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/hy-16dc4fb9234442e404351cc782b64771f8a239dcacd29214d086bb39dc6c321d.js
I, [2021-02-12T14:26:34.723535 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/ca-82930fb7a7f128e844d71693903745fc52371ce48fb049832d6d0624de8f8b5a.js
I, [2021-02-12T14:26:34.905840 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/be-96a5f9e2ada7781d23953767acfaf31e0910205bef176603ef983d0d8dae28c9.js
I, [2021-02-12T14:26:35.087048 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/sr-6c9c4abf4f6f272d877119dda816297752f50bab7687f70c6ec28cc73f66bb8b.js
I, [2021-02-12T14:26:35.281229 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/ko-2375b0b576cc1848c0dcf303891a2edd6278c0fd70b082bf07b159e837871545.js
I, [2021-02-12T14:26:35.435334 #4880] INFO -- : Gravando /var/www/discourse/public/assets/locales/en_GB-30c5baa998778b956eaa9ddfe1d552ebcbdf9680c93c90f8fa6d566c6c8641ab.js
I, [2021-02-12T14:26:35.447016 #4880] INFO -- : Gravando /var/www/discourse/public/assets/docker-manager-app-5c1a220b23e0afaccd100a14bca77a38de5520361fc84294195060946b019e25.js
I, [2021-02-12T14:26:35.982603 #4880] INFO -- : Gravando /var/www/discourse/public/assets/docker-manager-app-614579ae5251889ca5e969015bf9ca949b7956ba0526e62a25211c3d09a6b721.css
I, [2021-02-12T14:26:36.145613 #4880] INFO -- : Gravando /var/www/discourse/public/assets/docker-manager-vendor-9709990270a4ade37544c98dda3cfad18f77cdf6cd433291c3c5ef7bd25cb50d.js
I, [2021-02-12T14:26:36.151071 #4880] INFO -- : Gravando /var/www/discourse/public/assets/docker-manager-vendor-e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855.css
I, [2021-02-12T14:26:36.155783 #4880] INFO -- : Gravando /var/www/discourse/public/assets/images/docker-manager-aff8eaea0445c0488c19f8cfd14faa8c2b278924438f19048eacc175d7d134e4.png
I, [2021-02-12T14:26:36.568407 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-chat-integration-888e776293e20f1db62f4d0b044aec250a2a07aa6a638c7f1ec7dca47c33f3dc.js
I, [2021-02-12T14:26:36.599931 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-details-9be9806ef2338ede8e5c567dfd5b521aaad27d01694f01c604516118466d2120.js
I, [2021-02-12T14:26:37.010425 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-local-dates-085df7b6d1a298c1715bebab5b6a4611defbce5de303a87abf7d627bae61fffb.js
I, [2021-02-12T14:26:37.110534 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-math-098a79094dfd8c2dc3e54bd4d314669578c0ebc8756d18211c4e84f5c96443d5.js
I, [2021-02-12T14:26:37.134782 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-narrative-bot-0b1e40d099d739cee23bbad45c2fb5eac1dcaaba028fdc9fa21b9e32930ec40b.js
I, [2021-02-12T14:26:37.286429 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-presence-0165b3e3b684abf51b52c5170936daf0ef0a445070af773586dc3636f90f957d.js
I, [2021-02-12T14:26:37.415777 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-solved-d8a57b639c6586da7ebca0416be123fe4e9b1d7365543d14186f2b89a56d9b6a.js
I, [2021-02-12T14:26:37.478806 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/discourse-spoiler-alert-88fd1a561e59e7197797c0c4f0a000254e87ce58e6a4136dbc0daacad1e85b7e.js
I, [2021-02-12T14:26:37.498902 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/docker_manager-ad177f91e75af171560e0d79a81bd5ce7b5b01c80c9055a24d75e9370c9de28b.js
I, [2021-02-12T14:26:37.516247 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/lazy-yt-9db193c8caacf2e3b3a24ed4c63699ad497c210f668f467d95380efd00982345.js
I, [2021-02-12T14:26:40.601499 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/poll-b5418ac0c8943ba9a386a1332a42d8ba0a8f4173023239b09b8d9bdd08f3a11f.js
I, [2021-02-12T14:26:40.981609 #4880] INFO -- : Gravando /var/www/discourse/public/assets/plugins/styleguide-03523511cd853ca8572bd93886d4a7be217da71cfdb7f7c246ccba982c8ab11c.js
I, [2021-02-12T14:27:27.135153 #4880] INFO -- : Gravando /var/www/discourse/public/assets/application-81c1e81c85d7a88a679efa7269e7ef14acc80ee972df2e1b7ecdb564c76bdb52.js
I, [2021-02-12T14:27:27.139301 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicon-24b22a63aae0cf353d72b6b728504377bfc42edc6563f202e3a1401763497249.ico
I, [2021-02-12T14:27:27.142644 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/amazon-32233ce06b62096ce24f7e6a87a466972e0fbaab4df8c0b8c080abb331893d9f.png
I, [2021-02-12T14:27:27.145297 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/apple-37604b02a18539464c2af0ac2e88aa910172eb41ac295fb252fa9df490052cf4.png
I, [2021-02-12T14:27:27.149399 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/discourse-2c77f44366f7981baebf4ecad9b30060bd82a296967466a5d65e7fa042e7e31b.png
I, [2021-02-12T14:27:27.152399 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/github-766534fc8cb40a67bf050bd084db1151f1a5c6879675f281f5f1cb51eb1a31c8.png
I, [2021-02-12T14:27:27.157349 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_branding/logo_calendar_128px-f426f7f40ccb7f7f07cc473cbebb291664506356dd56d9d43953d76664a2d957.png
I, [2021-02-12T14:27:27.161113 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_branding/logo_calendar_48px-f2530faed46d5e34385114c3ff3eee0e6098a1c68247e1e85f99054de506a627.png
I, [2021-02-12T14:27:27.165911 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_branding/logo_docs_48px-9a05553acfa99570b278d07f18fec279a3bc6ef2063fef9864b22da68b30f4da.png
I, [2021-02-12T14:27:27.169086 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_branding/logo_drive_48px-2f4ea1916b1916d5714cd3ff95ad584d3aaa6711be4eb107e1988efa073ee2e0.png
I, [2021-02-12T14:27:27.172358 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_branding/logo_forms_48px-a30e9255c6ee0f4da85576b3ab79b5f0bbb4f9cf5f7116b5939aba29c40b3d6c.png
I, [2021-02-12T14:27:27.177946 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_branding/logo_sheets_48px-9e96b7743ed1765c6a8d05f06f9035173dfd0b457663c5bb305ecba4cc98c19e.png
I, [2021-02-12T14:27:27.181739 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_branding/logo_slides_48px-50876957878e9afa9c68a8f1a28d2d01d18645a6c5670c5b412ce335b0a61f09.png
I, [2021-02-12T14:27:27.185100 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/google_play-128adb4c5cfa76a15b1b4c8afbb4a2db5503f79ce58f28b17a1dbab20f83697b.png
I, [2021-02-12T14:27:27.188679 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/instagram-c11e16559e70f974a3c52186c9fdefa4debc653d60def1be1196c0add54598aa.png
I, [2021-02-12T14:27:27.191901 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/pdf_48px-11e5b37a9b8e941eee7da4eff572525fa7a872dea8ac0325531d4e4831ee5448.png
I, [2021-02-12T14:27:27.194438 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/pdf_64px-c7451be3289fe894e1b84be566f57e96fd7339249974a831aa74dd7b21351f68.png
I, [2021-02-12T14:27:27.196722 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/rottentomatoes-d65e8ee6b0ae4302aecacc6ffeefb284bf4efba93c4049faadaab55759ecc833.png
I, [2021-02-12T14:27:27.200802 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/stackexchange-d4476e9e7947492e31563225692eb35f25ffb5073773e20d334f94fce85648ac.png
I, [2021-02-12T14:27:27.204005 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/twitter-2563ce2cc8e6b20d97b05ef7de1f03204bb4263e50815b0d4e6a932acb690e32.png
I, [2021-02-12T14:27:27.207075 #4880] INFO -- : Gravando /var/www/discourse/public/assets/favicons/wikipedia-8feddaf7544a35c824f2e4274227fe8e7e7af71ddfe26523fe5fe20497cf5799.png
I, [2021-02-12T14:27:27.211641 #4880] INFO -- : Gravando /var/www/discourse/public/assets/logo-dev-0b53838dc1ee09248b94e3d4aa5c70d4a9897f26b8133d147e17bf8d41d3be7b.png
I, [2021-02-12T14:27:27.215388 #4880] INFO -- : Gravando /var/www/discourse/public/assets/logo-single-dev-5545f7e0d4d1d1d5ba821a6d8c1e394033558324e90acc1c6045cf382b4880c8.png
I, [2021-02-12T14:27:27.218750 #4880] INFO -- : Gravando /var/www/discourse/public/assets/logo-single-d7a0dacc998273856c42737dba8693fbdb9e5fd929d36afeb3f13844f147e865.png
I, [2021-02-12T14:27:27.222009 #4880] INFO -- : Gravando /var/www/discourse/public/assets/logo-ba2f2da6eac779d8b34d4aa977be739e4de07f7d34e970f4b8ac32682706c122.png
I, [2021-02-12T14:27:27.226868 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/check-f64a79b1bde9a9e1f6fdc1ab382163596a06e3ae71443bb8c8231aa595bcbc80.png
I, [2021-02-12T14:27:27.230281 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/discourse-bdbc548a4e328f39b017bb143b679c5dfe7b060574760cd71d77971c2a9eff1f.png
I, [2021-02-12T14:27:27.233295 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/group_mentioned-012ba348812e600c5532b8ccc08e8767b16fd126f3c7bcedcbdedaba640721d6.png
I, [2021-02-12T14:27:27.236377 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/linked-02191f88212f5cba22760235346da4e238eb9a4c9056cac92965a940eeaa02d0.png
I, [2021-02-12T14:27:27.240089 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/mentioned-012ba348812e600c5532b8ccc08e8767b16fd126f3c7bcedcbdedaba640721d6.png
I, [2021-02-12T14:27:27.242761 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/posted-918b5c4333d62ea140dfc63a49d1ee60e71f00418b8f2f7fa91bb65a2c995830.png
I, [2021-02-12T14:27:27.245471 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/private_message-77576c8c5017882f813792be99ee57b2ddaa417c2baf74255a9899867ad66b97.png
I, [2021-02-12T14:27:27.248953 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/quoted-a1bf4d7b4f4ad6b34b43d60143a7e07ddc030855eae2cf9308011ba91a3ce168.png
I, [2021-02-12T14:27:27.251945 #4880] INFO -- : Gravando /var/www/discourse/public/assets/push-notifications/replied-918b5c4333d62ea140dfc63a49d1ee60e71f00418b8f2f7fa91bb65a2c995830.png
I, [2021-02-12T14:27:27.255640 #4880] INFO -- : Gravando /var/www/discourse/public/assets/select2-spinner-167ca7c36c01a1e1ea29b6dc5ff154e0f5d1669e69ee7c2fd33e6f2f8bed9dce.gif
I, [2021-02-12T14:27:27.258474 #4880] INFO -- : Gravando /var/www/discourse/public/assets/select2-989b6d7958f96d9200676011d0784973a28290f24a33fa8bb11c99a3bdb17d45.png
I, [2021-02-12T14:27:27.261202 #4880] INFO -- : Gravando /var/www/discourse/public/assets/select2x2-4716447f68b44b59597bbc4ae471e5ed849873309fbaa689ae26b69494cc2ae3.png
I, [2021-02-12T14:27:27.263991 #4880] INFO -- : Gravando /var/www/discourse/public/assets/spinner_96-2aa4bebb9cae6fdb5cd0f962da0d86f9370606fbcb52156b1416fe194c110f8f.gif
I, [2021-02-12T14:27:27.281050 #4880] INFO -- : Gravando /var/www/discourse/public/assets/admin/package-9999be639c39a529092f53101c8b8ef21c32d5a572a396b0804cbe1f602ca60d.json
I, [2021-02-12T14:27:27.336917 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse/app/index-f8ba3cfadff66bd3faa8ae0122e0ef33e6336bedbffe9c1ca2e482a64fe7d909.html
I, [2021-02-12T14:27:27.347281 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse/config/optional-features-686dfa136f902425f302ca150899f1476f216a8318593e81c73e05c1d274c8de.json
I, [2021-02-12T14:27:27.349410 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse/package-0ad2fe0fb1145c4f89dcbd77e3af4ea4bceeff488548e0acfdafee538bbc911c.json
I, [2021-02-12T14:27:27.356964 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse/tests/index-4dd02b56e1105f7c9909f24dd98baa225b8d193b39278561064513adc52ac0e4.html
I, [2021-02-12T14:27:27.366172 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse/yarn-fe3ee940fdf3218165ac72714167cf92e8fb5cd2a2cad2a9e8e9bf8c7f723f58.lock
I, [2021-02-12T14:27:27.369252 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse-common/package-76394df51a9d2dde9907bcac46e31d9bacddc04a1944ec759791d0f6cb7745cb.json
I, [2021-02-12T14:27:27.373394 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse-common/yarn-1f9507dfae63854c638a6a2b81927aa37402324e3e12d80493b8dfe16635caba.lock
I, [2021-02-12T14:27:27.376016 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse-hbr/package-2050287607b31f70fd128a68f5800256e1ce6ee837095733d2f6c5ae13d25502.json
I, [2021-02-12T14:27:27.380368 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse-hbr/yarn-bd8529534fccb0d05ae1acb7b46239ee3f8028a3688cc938d00e490535e61f9a.lock
I, [2021-02-12T14:27:27.383353 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse-widget-hbs/package-3c02f717bcfb75c715ea40cc367668562f4336d921fc4d8258c3375276c87db4.json
I, [2021-02-12T14:27:27.387599 #4880] INFO -- : Gravando /var/www/discourse/public/assets/discourse-widget-hbs/yarn-d65a2ff4665f81d7ae1ec95a890e39ca96841104840d6cbe110779317c9e00eb.lock
I, [2021-02-12T14:27:27.390155 #4880] INFO -- : Gravando /var/www/discourse/public/assets/docs/yuidoc-d4a0515b77168bf39e922e83e51c6c53e4d0d026424d18632579fb780e62823d.json
I, [2021-02-12T14:27:27.393090 #4880] INFO -- : Gravando /var/www/discourse/public/assets/package-92a050046ac558d34f2e54442755c280e5f18397d099a776e95079be5b2539ad.json
I, [2021-02-12T14:27:27.396282 #4880] INFO -- : Gravando /var/www/discourse/public/assets/pretty-text/package-ba946b9dced6a4ff28f8499707edd3781c1db8047fcc77df5bc16cf29a430b56.json
I, [2021-02-12T14:27:27.400513 #4880] INFO -- : Gravando /var/www/discourse/public/assets/pretty-text/yarn-afb1e44bb91225a114ffec9e5b5153cb456ba4061f1d6f17a7cefc8e2f320619.lock
I, [2021-02-12T14:27:27.404636 #4880] INFO -- : Gravando /var/www/discourse/public/assets/select-kit/package-49daa780536292224da02a386e07c1b65ad91d28be297eb7beeaeff3564e56b1.json
I, [2021-02-12T14:27:27.408805 #4880] INFO -- : Gravando /var/www/discourse/public/assets/select-kit/yarn-2d623b95679464de1222583382d58440f4b4073b10fc05ebb54bdbe950a5165c.lock
I, [2021-02-12T14:27:27.442574 #4880] INFO -- : Gravando /var/www/discourse/public/assets/yarn-0985ac9e835fdbe37c992d1f49ba7f8e3ab7ca87550a8f95c1e9ae51938c9c4a.lock
I, [2021-02-12T14:29:17.967881 #1] INFO -- : Baixando MaxMindDB...
I, [2021-02-12T14:29:17.975400 #1] INFO -- : Arquivo > /usr/local/bin/discourse chmod: +x chown:
I, [2021-02-12T14:29:17.981262 #1] INFO -- : Arquivo > /usr/local/bin/rails chmod: +x chown:
I, [2021-02-12T14:29:17.987177 #1] INFO -- : Arquivo > /usr/local/bin/rake chmod: +x chown:
I, [2021-02-12T14:29:17.992784 #1] INFO -- : Arquivo > /usr/local/bin/rbtrace chmod: +x chown:
I, [2021-02-12T14:29:17.998147 #1] INFO -- : Arquivo > /usr/local/bin/stackprof chmod: +x chown:
I, [2021-02-12T14:29:19.521797 #1] INFO -- : Arquivo > /etc/update-motd.d/10-web chmod: +x chown:
I, [2021-02-12T14:29:19.548414 #1] INFO -- : Arquivo > /etc/logrotate.d/rails chmod: chown:
I, [2021-02-12T14:29:19.551930 #1] INFO -- : Arquivo > /etc/logrotate.d/nginx chmod: chown:
I, [2021-02-12T14:29:19.557738 #1] INFO -- : Arquivo > /etc/runit/1.d/00-ensure-links chmod: +x chown:
I, [2021-02-12T14:29:19.563283 #1] INFO -- : Arquivo > /etc/runit/1.d/01-cleanup-web-pids chmod: +x chown:
I, [2021-02-12T14:29:19.568391 #1] INFO -- : Arquivo > /root/.bash_profile chmod: 644 chown:
I, [2021-02-12T14:29:19.571660 #1] INFO -- : Arquivo > /usr/local/etc/ImageMagick-7/policy.xml chmod: chown:
I, [2021-02-12T14:29:19.572062 #1] INFO -- : Substituindo (?-mix:server.+{) por limit_req_zone $binary_remote_addr zone=flood:10m rate=$reqs_per_secondr/s;
I, [2021-02-12T14:29:19.572513 #1] INFO -- : Substituindo (?-mix:location @discourse {) por location @discourse {
I, [2021-02-12T14:29:19.617473 #1] INFO -- : Arquivo > /etc/runit/1.d/remove-old-socket chmod: +x chown:
I, [2021-02-12T14:29:19.622824 #1] INFO -- : Arquivo > /etc/runit/3.d/remove-old-socket chmod: +x chown:
I, [2021-02-12T14:29:19.623035 #1] INFO -- : Substituindo (?-mix:listen 80;) por listen unix:/shared/nginx.http.sock;
I, [2021-02-12T14:29:19.646385 #1] INFO -- : Substituindo (?-mix:listen 443 ssl http2;) por listen unix:/shared/nginx.https.sock ssl http2;
I, [2021-02-12T14:29:19.700427 #1] INFO -- : > echo "Início dos comandos personalizados"
I, [2021-02-12T14:29:19.702743 #1] INFO -- : Início dos comandos personalizados
I, [2021-02-12T14:29:19.703200 #1] INFO -- : > echo "Fim dos comandos personalizados"
I, [2021-02-12T14:29:19.705306 #1] INFO -- : Fim dos comandos personalizados
I, [2021-02-12T14:29:19.705598 #1] INFO -- : Encerrando processos assíncronos
I, [2021-02-12T14:29:19.705780 #1] INFO -- : Enviando INT para HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 50
Olhando as informações do Proxmox para a VM, a RAM parece estar ok, o CPU parece estar ok:
