I installed Discourse on a Synology RackStation using the Discourse Docker package from the Synology Package Center. It shows the package is published by Civilized Discourse Construction Kit so I assume it’s an officially supported package.
Trouble is there is zero documentation with it and I’ve tried for 2 days to get email notifications to work without success. This means I’m stuck, unable to even activate my admin account to complete the setup.
I’ve read through many suggestions here on the forum but most of them involve editing .yml files and I can’t even find those files on my system.
I need some guidance on troubleshooting this issue, starting with the basics of how to access configuration on the Synology NAS.
If you don’t install using the install cloud instructions, it’s not officially supported.
You need to get the good people at synology to help you with the installer that they made.
Or
If you can ssh into the box, and it runs Docker, both of which seem fairly likely, you can follow the install instructions that I linked to when you asked the same question in another topic. And then, you should be able to run disourse-setup and follow the mail troubleshooting document and all of the other information that you have found here that by your own report doesn’t apply to your situation.
I did contact Synology and their reply was “…we did not develop the package…” and just pointed me to this forum.
Unfortunately that topic (along with my entire account) was removed yesterday when my account was mistakenly flagged for spam. I spent a good bit of time yesterday with support just to regain the ability to post. Could you please link to those threads again?
The docker wasn’t really docker, the discourse was a really old container which wouldn’t update, and synology isn’t a full Linux install.
@Tyson_Clugy: if it were me, I would spend a few hours seeing if the syno/docker/discourse package can be made to work, and if not then I would create a VM on the Syno, install Ubuntu, then follow the standard Discourse install.
So it turns out the package was outdated and I decided to just start over from scratch.
I set up a VM running Ubuntu Server and installed Discourse using the official method and everything is up and running smoothly.
