Does anymore know if it is possible to install Discourse on my Synology NAS?
I have tried the Package Manager Discourse Install but this is very old (version 1.2.1).
So I want to install it manual via “discourse-setup”. Is this possible on a Synology NAS with docker support?
No, we’ve had a number of support threads here on the topic. The existing Synology package is ancient and has a number of configuration pains, the maintainer appears to have abandoned it, to all intents and purposes it’s a dead-end.
It’s certainly possible to install, but whether that install is supportable is the better question. The currently supported install method definitely doesn’t work as-is.
As I said above the supported install doesn’t work as-is. It’s not something we can help to bodge here because it creates support problems down the line.
Anyone who comes up with an install or package inherits the support responsibility in the process.
That’s a shame!
I’m new here, researching forum software for a forum that we don’t want to look like a forum. If you see what I mean.
At present, some of my co-conspirators are hooked on Wordpress… I’ve never really liked it, and my only interactions have left me feeling that plugins are buggy and typically poorly supported.
My plan was to install Discourse on my Synology NAS,as that’s currently the only platform I have running a Linux-type OS. Given what has been said here, I’ll forgo that idea!
I’ve been thinking of a low power box for a DIY NAS for some time. Perhaps I’ll move that plan up the to-do list.
You can run a normal install on Synology, but I would only use it for a test platform. It works fine on my 1515+, but it’s probably only a question of time until the docker version supported by Synology is too far behind for what Discourse needs.
Estoy de acuerdo con Christian; yo también uso mi QNAP más allá de un dispositivo de almacenamiento básico y sería perfecto para esto. El mío tiene paquetes relativamente actualizados, pero me cuesta la implementación porque no soy usuario de SSH.
Sé que este es un tema antiguo, pero recientemente tuve la misma pregunta. Siguiendo el consejo de Andrew Waugh, dediqué un tiempo a resolver los problemas y escribí un artículo sobre cómo logré que todo funcionara. Así que, por si alguien en el futuro se encuentra con las mismas dudas, espero que esto sea de ayuda.
