Solution grayed out on flagged topic
Reproduction steps:
  1. Topic is hidden by community flags. (Flag the post twice)
  2. Mark a solution that is not currently the reply.
  3. The solution will appear grayed out as if it is the same element as a flagged post.
I can’t repro this. Having a flagged and hidden post in the topic doesn’t add an unintended opacity to the quoted solution:
Unless you mean the OP is flagged? In which case it would be expected that the solution quoted in there would also acquire the same opacity as the post:
I am refering to when the OP is flagged, then it becomes grayed out
