I’m seeing:
Where I used to see:
Is this the coloring “fix” mentioned in Discourse 2.5.0.beta6 Release Notes? Or is this an unintended side effect of the change made in UX: fix solved colors · discourse/discourse-solved@4e687d4 · GitHub?
I’m seeing:
Thanks for the report! I’m pretty sure the fix in the release notes is that commit. @Johani can you take another look? It looks fine when in the button form:
But the color was lost in the non-button version (view a solved topic when logged out, for example):
This should correct the color for the label we show to anon users
Thanks for reporting the issue @seanblue ![]()
