jomaxro
(Joshua Rosenfeld)
June 1, 2020, 6:30pm
1
New features in 2.5.0.beta6
End of IE support
In preparation for the release of Discourse 2.5 later this month, support for IE11 has been disabled by default as of this beta. Support for IE11 will be completely removed in Discourse 2.6.0.beta1.
Why is Discourse dropping IE11 support?
From the beginning, Discourse has been built for the future of the internet. Discourse relies on current, evolving web standards as it is developed. Microsoft is no longer updating IE11 to support modern web standards, they are only providing security updates and support. Given the lack of updates, Discourse development has become hindered by IE11. When new features are developed, they frequently require IE-specific code to ensure they work as expected, as…
Update and Homogenize Menu Styling
We’ve gone through all the various menus in Discourse and updated their styling, removing the older, grey “button-like” style used in the past.
Even more!
But wait, there’s more! We do our best to highlight new features and changes for you, but there’s always too many changes to detail. For a full list of new features, bug fixes, UX improvements, and more, be sure to review the Additional Features and Fixes listed below.
jomaxro
(Joshua Rosenfeld)
Security Updates
This beta includes 3 security fix for issues reported by our community and HackerOne .
Make find topic by slug adhere to SiteSetting.detailed_404
Use FinalDestination for topic embeds
Missing security check prior to redirect
Plugin improvements
Onebox
Improve Instagram Support
Code Review
Encrypt
Bug fix: remove correct user
Graphviz
Add more detailed error messages
Bug fixes
Knowledge Explorer
Improve topic status icon handling
Subscriptions
Miscellaneous improvements
Patreon
Update wpdc_auto_publish_overridden post metadata when a post is unlinked from Discourse to prevent the plugin from attempting
to publish updates to the post to Discourse
Fix issue with the Auto Publish setting for posts that were unlinked from Discourse prior to WP Discourse version 2.0.3
Add static get_discourse_comments function to allow comments to be displayed without loading the comments template
User Notes
Solved
Calendar
Font Awesome Pro
New Features
New plugin outlet under badges page title
Notify admins about old credentials
Download remote images even for old posts
Optionally allow tags in topic tracking state
Show a detailed 404 page for private topics
Bug Fixes
Support exporting reports which reference topics
Correct the misalignment of popover arrows
Don’t change the button height when spinner appears
Restore the ability to rebake posts in deleted topics
Handle files removed between glob and mtime
z helper doesn’t resolve inside calc
Topic-admin-popup-menu was overflowing on small screens
Support IRIs (unicode URIs) when pulling hotlinked images
Pull hotlinked images even when edited by system users
Invalidate database theme cache when hostname changes
Pins down highlight.js to the last commit of the v9 tree
Don’t rerender whole users page while typing on input.
Muted tags removed topics with no tags from counts
Don’t raise an exception if a topic cannot be retrieved
Allows to define label/title properties for display instead of name
Sending messages to groups with non-lowercase names
Broken query if upload id is missing
Allows to have custom emoji translation without static file
Add X-Robots-Tag header for check_xhr-covered GET actions, too
Don’t send digests to users with no primary email
Correctly set values and defaults for group-form-interaction-fields
When destroying a draft always ensure saving is done
Opening cancel draft dialog broke autosave
Pass current_user to TopicQuery in for categories_and_top_topics
Updates variables for HTML to use em instead of px in font-size
Wizard fails to start when default_theme_id is -1
Wizard previews if color step is excluded
XML files could be detected as SVG files
UX Changes
Remove box-shadow from kbd, unify styling
Fix border radius artifacts on dashboard pills
Remove the period after “Enable Notifications” button
Fix inputs alignment in admin/customize/colors
Position topic admin menu next to wrench
Make the menu links header within the user panel more flexible
Better alignment of icons in notifications menu
Relocate before-topic-list outlet so it shows up on Top as well
Remove in:unpinned filter from advanced search page.
Fix activity column display in wizard homepage step
Remove edit PM button
More consistent alignment of topic timer’s selected datetimes
Don’t show the suspension date if the user is permantently suspended.
Keep focus on input after selecting an autocomplete option
Do not show redundant user count
Add spacing between +member_count and “more”
Rename Priority to score for sorting.
Performance
Use more efficient query when checking for existence.
