I have setup discourse with the following stack:
- Cloudflare (free plan, SSL and CDN)
- AWS Application Load Balancer (not free, does termination of SSL)
- AWS EC2 t2.small server
- This guide discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
I wanted the website to be https (who does http anymore?), but quickly banged my head against the wall.
Solutions I found:
- do NOT install docker.io from the apt Ubuntu repositories as it is not supported
- do NOT add cloudflare template to app.yml
- remove the lines everybody is saying to add:
proxy_set_header X-Forwarded-Proto https;or as per templateproxy_set_header X-Forwarded-Proto $thescheme;
The reason for the last two is that I was getting a Bad CSRF and the reason was (probably) because proxy headers were being changed mid-stream.
I hope this helps somebody not avoid all the time I wasted with what should be a simple one container setup.
