Solved Topic and Moderator Response Stats by Category
:discourse: The following reports require the Discourse Solved plugin to be enabled.
The following Data Explorer queries are designed to analyze topics within each category on a site, focusing on metrics related to solving topics and moderator responses to topics. They operate within a specified date range and optionally filter by category name. These queries assume that topics in all categories can be solved.
Admins can use these reports to understand how effectively topics are being solved within different categories, and identify areas where moderator response times can be improved. By understanding the dynamics of topic resolution in parent and subcategories, admins can make informed decisions to improve community engagement and support.
Both queries have the same parameters, and very similar results.
Parameters
  • :start_date and :end_date: Define the date range for the analysis.
  • :category_name: Optionally filters the results to a specific category.
Results
  • date / date_range : The specific date or the start of the period for which the data is reported, and specifies the granularity of the time period covered by each row of data (month).
  • parent_category_name / category_name: The name of the category or specific subcategory to which the data pertains.
  • total_number_of_topics: Total number of topics created in the specified category or subcategory within the date range.
  • number_of_solved_topics: Total number of topics that were marked as solved within the specified category or subcategory and date range.
  • avg_time_to_solve_hours: Average time taken to mark a solved topic as solved, measured in hours.
  • percent_solved_under_24h: Percentage of topics that were solved within 24 hours of being posted (excludes topics that have not been solved).
  • avg_solved_topics_moderator_time_to_first_response_hours: Average time it took for a moderator to respond to topics that were eventually marked as solved, measured in hours.
  • avg_time_to_first_response_hours: Average time taken for the first response to be posted in a topic, measured in hours.
  • percent_all_topics_with_moderator_responses_under_24h: Percentage of all topics that received a moderator response within 24 hours of being posted.
This query groups results by main (parent) categories.
--[params]
-- date :start_date = 2023-01-01
-- date :end_date = 2025-01-01
-- null string :category_name
WITH solved_topics AS (
    SELECT
        t.category_id,
        t.id AS topic_id,
        DATE_TRUNC('month', t.created_at) AS month,
        MIN(p.created_at) FILTER (WHERE p.id = dsta.answer_post_id) AS solution_posted_at,
        MIN(p.created_at) FILTER (WHERE p.user_id = u.id AND u.moderator AND p.post_number > 1) AS first_moderator_response
    FROM topics t
    JOIN discourse_solved_solved_topics dsst ON dsst.topic_id = t.id
    JOIN discourse_solved_topic_answers dsta ON dsta.solved_topic_id = dsst.id
    JOIN posts p ON t.id = p.topic_id
    JOIN users u ON p.user_id = u.id
    WHERE t.archetype = 'regular'
    GROUP BY t.category_id, t.id, month
moderator_responses AS (
    SELECT
        topic_id,
        MIN(created_at) AS first_response
    FROM posts
    WHERE user_id IN (SELECT id FROM users WHERE moderator)
    AND post_number > 1
    GROUP BY topic_id
moderator_response_stats AS (
    SELECT
        pc.id AS parent_category_id,
        COUNT(*) FILTER (WHERE EXTRACT(EPOCH FROM (mr.first_response - t.created_at))/3600 < 24) AS topics_with_first_response_under_24h,
        COUNT(*) AS total_topics
    FROM topics t
    JOIN categories c ON t.category_id = c.id
    LEFT JOIN categories pc ON c.parent_category_id = pc.id OR c.id = pc.id -- Includes top-level categories as their own parents
    LEFT JOIN moderator_responses mr ON t.id = mr.topic_id
    AND t.created_at >= :start_date
    AND t.created_at <= :end_date
    GROUP BY pc.id, month
total_topics_per_category AS (
    SELECT
        COUNT(*) AS total_number_of_topics
    FROM topics t
category_hierarchy AS (
    SELECT
        c.id AS category_id,
        c.name AS category_name,
        COALESCE(pc.id, c.id) AS parent_category_id, -- Use the category itself if it has no parent
        COALESCE(pc.name, c.name) AS parent_category_name
    FROM categories c
solved_stats AS (
    SELECT
        st.month,
        ch.parent_category_id,
        COUNT(*) AS number_of_solved_topics,
        AVG(EXTRACT(EPOCH FROM (st.solution_posted_at - t.created_at))/3600) AS avg_time_to_solve_hours,
        AVG(CASE WHEN EXTRACT(EPOCH FROM (st.solution_posted_at - t.created_at))/3600 < 24 THEN 1 ELSE 0 END) AS percent_solved_under_24h,
        AVG(EXTRACT(EPOCH FROM (mr.first_response - t.created_at))/3600) AS avg_time_to_first_response_hours,
        AVG(EXTRACT(EPOCH FROM (st.first_moderator_response - t.created_at))/3600) AS solved_topics_avg_time_to_first_response_hours,
        COALESCE(mrs.topics_with_first_response_under_24h::FLOAT / NULLIF(mrs.total_topics, 0), 0) AS percent_moderator_responses_under_24h
    FROM solved_topics st
    JOIN topics t ON st.topic_id = t.id
    JOIN category_hierarchy ch ON t.category_id = ch.category_id
    LEFT JOIN moderator_responses mr ON st.topic_id = mr.topic_id
    LEFT JOIN moderator_response_stats mrs ON ch.parent_category_id = mrs.parent_category_id AND DATE_TRUNC('month', t.created_at) = mrs.month
    WHERE t.created_at >= :start_date
    GROUP BY st.month, ch.parent_category_id, mrs.topics_with_first_response_under_24h, mrs.total_topics
SELECT
    st.month::date AS date,
    'month' AS date_range,
    ch.parent_category_name,
    ttpc.total_number_of_topics,
    st.number_of_solved_topics,
    ROUND(st.avg_time_to_solve_hours::numeric,2) AS avg_time_to_solve_hours,
    ROUND((st.percent_solved_under_24h * 100)::numeric, 2) AS percent_solved_under_24h,
    ROUND(st.solved_topics_avg_time_to_first_response_hours::numeric,2) AS avg_solved_topics_moderator_time_to_first_response_hours,
    ROUND(st.avg_time_to_first_response_hours::numeric,2) AS avg_time_to_first_response_hours,
    ROUND((st.percent_moderator_responses_under_24h * 100)::numeric, 2) AS percent_all_topics_with_moderator_responses_under_24h
FROM solved_stats st
JOIN category_hierarchy ch ON st.parent_category_id = ch.parent_category_id
LEFT JOIN total_topics_per_category ttpc ON st.parent_category_id = ttpc.parent_category_id AND st.month = ttpc.month
WHERE (:category_name IS NULL OR ch.parent_category_name = :category_name)
GROUP BY date,st.month,ch.parent_category_name,ttpc.total_number_of_topics,st.number_of_solved_topics,st.avg_time_to_solve_hours,st.percent_solved_under_24h,st.solved_topics_avg_time_to_first_response_hours,st.avg_time_to_first_response_hours,st.percent_moderator_responses_under_24h
ORDER BY st.month, ch.parent_category_name
Example Results
date date_range parent_category_name total_number_of_topics number_of_solved_topics avg_time_to_solve_hours percent_solved_under_24h avg_solved_topics_moderator_time_to_first_response_hours avg_time_to_first_response_hours percent_all_topics_with_moderator_responses_under_24h
2023-01-01 month General Discussion 150 100 12.5 75.00 5.00 6.00 80.00
Solved Topic and Moderator Response Stats by Sub-Category
This query groups results by sub-categories.
--[params]
    SELECT
        t.category_id,
        t.id AS topic_id,
        MIN(p.created_at) FILTER (WHERE p.id = ua.target_post_id) AS solution_posted_at,
    FROM topics t
    JOIN user_actions ua ON ua.target_topic_id = t.id AND ua.target_post_id = p.id
    AND ua.action_type = 15 -- action_type for 'accepted solution'
    SELECT
        topic_id,
    FROM posts
    AND post_number > 1
    GROUP BY topic_id
    SELECT
        t.category_id,
    FROM topics t
    GROUP BY t.category_id, month
    SELECT
        category_id,
        DATE_TRUNC('month', created_at) AS month,
    FROM topics
    WHERE archetype = 'regular'
    AND created_at >= :start_date
    AND created_at <= :end_date
    GROUP BY category_id, month
solved_stats AS (
    SELECT
        st.month,
        st.category_id,
    LEFT JOIN moderator_response_stats mrs ON t.category_id = mrs.category_id AND DATE_TRUNC('month', t.created_at) = mrs.month
    GROUP BY st.month, st.category_id, mrs.topics_with_first_response_under_24h, mrs.total_topics
    SELECT
    FROM categories c
SELECT
    ch.category_name,
    ROUND(st.avg_time_to_first_response_hours::numeric,2) AS avg_all_topics_moderator_time_to_first_response_hours,
JOIN category_hierarchy ch ON st.category_id = ch.category_id
LEFT JOIN total_topics_per_category ttpc ON st.category_id = ttpc.category_id AND st.month = ttpc.month
WHERE (:category_name IS NULL OR ch.parent_category_name = :category_name OR ch.category_name = :category_name)
ORDER BY st.month, ch.parent_category_name, ch.category_name
Example Results
date date_range parent_category_name category_name total_number_of_topics number_of_solved_topics avg_time_to_solve_hours percent_solved_under_24h avg_solved_topics_moderator_time_to_first_response_hours avg_all_topics_moderator_time_to_first_response_hours percent_all_topics_with_moderator_responses_under_24h
2023-01-01 month General Discussion Feedback 50 30 8.00 80.00 4.00 5.00 85.00
