Une sorte d'équivalent de « Réponses à » sur mobile
On mobile when you tap the the avatar and arrow at the upper right of a post to read the post someone is replying to - there’s no easy way (that I can find) to navigate to the post you were originally at - I’ve had to just scroll back down.
I can see how the full “Replies to” dropdown like on the desktop can be hard to make look good on mobile. Perhaps there could be a button that takes you back to the post you were previously at before making a jump in a topic or even just a way to go back to the original post after seeing what post they were replying to.
I experimented a few years back with “collapsing the stream” between the two posts. I think this works well on mobile. Cause it is easy to expand the stuff in the middle after you click it.
Before clicking in “in reply to”
post 1
post 2
post 3
post 4 [reply to 1]
After clicking
post 1
[ 2 more posts, click to expand ]
post 4
3 « J'aime »
If you are scrollling up ↑, you can, because the big blue BACK button will appear above the topic progress bar. If you are scrolling down ↓ deeper in the topic you are pushing your read point further down so that’s irrevocable.
I just tried that out and the way it jumps wasn’t obvious to me. Some screenshots:
Start here.
Tap top right avatar for the bottom post.
Tap back.
I really like this idea!
Seeing how it’s done on mobile would also help me with some other stuff…I’ve been trying on and off to get that same effect onto mobile mode, but with the user filter.
