Sommige gebruikersavatars zijn veranderd naar het standaard grijze icoon na het upgraden van Discourse naar 2.8.0.beta1
Hello everyone, another problem after upgrading discourse to 2.8.0.beta1.
I found that some user’s avater is changed to the fefault grey icon, while others did not.
Can anyone help restore use’s avatar back? Thanks.
Yes, that post is too old.
I found another recent post
successfully get some user’s avatar back by using the following command
cd /var/discourse
./launcher enter app
rake avatars:refresh
But there are still some users’ avatar are grey icon.
Another strange behavior.
For the troed user, if I click the icon
I can see his avatar.
while some other user shows a bigger grey icon.
