Desculpe, ocorreu um erro ao atualizar o Discourse
Not able to update, error message
Sorry, there was an error upgrading Discourse. Please check the logs below.
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 1397
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Waiting for Unicorn to reload........
Waiting for Unicorn to reload.........
Waiting for Unicorn to reload..........
Waiting for Unicorn to reload...........
Waiting for Unicorn to reload............
Waiting for Unicorn to reload.............
Waiting for Unicorn to reload..............
Waiting for Unicorn to reload...............
Waiting for Unicorn to reload................
Waiting for Unicorn to reload.................
Stopping 3 Unicorn worker(s), to free up memory
Stopping job queue to reclaim memory, master pid is 1401
Docker Manager: FAILED TO UPGRADE
#<Errno::ESRCH: No such process>
/var/www/discourse/lib/demon/base.rb:84:in `kill'
/var/www/discourse/lib/demon/base.rb:84:in `stop'
/var/www/discourse/lib/demon/base.rb:22:in `block in stop'
/var/www/discourse/lib/demon/base.rb:21:in `each'
/var/www/discourse/lib/demon/base.rb:21:in `stop'
config/unicorn.conf.rb:96:in `block (2 levels) in reload'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:62:in `kill'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:62:in `upgrade'
/var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:95:in `block in upgrade'
/var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:91:in `fork'
/var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:91:in `upgrade'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/abstract_controller/base.rb:195:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/callbacks.rb:135:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/notifications.rb:180:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/notifications.rb:180:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.3/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/abstract_controller/base.rb:136:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-6.0.3.3/lib/action_view/rendering.rb:39:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.1.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal.rb:190:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_controller/metal.rb:254:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/routing/route_set.rb:33:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/journey/router.rb:49:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/journey/router.rb:32:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/journey/router.rb:32:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/routing/route_set.rb:834:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/engine.rb:527:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/conditional_get.rb:40:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:336:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/cookies.rb:648:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.3/lib/active_support/callbacks.rb:101:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.9.4/lib/logster/middleware/reporter.rb:43:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/rack/logger.rb:37:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.3/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:23:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.3/lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.1.0/lib/mini_profiler/profiler.rb:235:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-3.3.2/lib/message_bus/rack/middleware.rb:61:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:176:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.7.0/lib/unicorn/http_server.rb:632:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.7.0/lib/unicorn/http_server.rb:728:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.7.0/lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.7.0/lib/unicorn/http_server.rb:144:in `start'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.7.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
Spinning up 3 Unicorn worker(s) that were stopped initially
Tente fazer a atualização via linha de comando em vez da interface web.
Recebi uma mensagem semelhante ontem e hoje para o plugin User-Notes e o plugin Discourse-Policy ao tentar atualizar. Outras atualizações de plugins funcionaram bem.
Se a resposta for a mesma, existe uma postagem que explica como atualizar via linha de comando para plugins específicos?
Obrigado.
