Problem
Large pasted blocks are increasingly common: AI output, documentation, articles, text from other sites. Readers often have no way of knowing where the content came from, which makes it harder to judge its accuracy and context.
Proposal
Prompt the user for source/citation if they paste more than 100 characters.
Example Solution using a Modal window
Modal window might not be the right method in the long run, but it’s easy to mock up and illustrate how this solution could look. Essentially when a user pastes a bunch of text a modal asks the users “Where is this text from” and provides options like:
Another website
User is asked to provide the url which is added as a label to the quote(see image)
Useful for traceability regardless of the desire to label AI content
AI Generated or Assisted
This adds a small label to the content
I wrote this elsewhere:
e.g. I wrote this in another editor. Just pastes like currently.
You can play with the mockup here ![]()
Benefits
- Encourages proper attribution of quoted material in general
- Lets honest users disclose AI use easily
Drawbacks and limits
- It relies on honesty. Users can choose a misleading option, or retype the text.
- Some communities may not want an AI label at all, so this would make sense as an opt-in site setting.
Open points
I’m 50/50 about this having a “skip” option. I worry it would be abused, but one the other hand this process adds friction and not all pasted content needs citation. Then again, not adding source applies burden to the reader, and the number of readers typically exceeds the
number of authors so surely the burden should sit with the author?
Related topic: Improved AI content labelling in the composer for post content - #16 by Tris20
