From Github I am used to specifying the language of the code block in the “info string” (name from commonmark spec), but it seems that Discourse does not do this. At least not this and the other Discoruse instance I am using.
When I inspect the resulting <pre><code> block it always has lang-auto set.
Examples
The following is YAML and has ```yaml specified, but is highlighted as CSS:
- include: scope:source.c#cparens
The following is (again) YAML and has ```yaml specified, but is highlighted as PHP:
- include: scope:source.c#parens
