SQL shared_drafts - will it be cached
I’m sorry, but I guess it’s not working properly yet.
v2.0.0.beta4 +205
http://toxu.blog/sql.htm
@eviltrout said the N+1 is fixed. What’s the issue? You are only on +205, you should be on +230 or better.
In fact, this problem is not solved in: v2.0.0.beta4 +230
I gave in PM (eviltrout) some details.
I believe this should fix it - I did not want the shared drafts to be returned by the global latest as it was confusing:
https://github.com/discourse/discourse/commit/2b161a2391a58e36e7238ce75805775da11308ea
Everything works fine. Thanks.
This topic was automatically closed after 5 hours. New replies are no longer allowed.
