Sshfs 和备份
您好,
我为一个小社区托管 Discourse。我们有一个非常小的、旧的 VPS。磁盘空间已无法容纳备份,所以我做了一个快速的技巧,将远程文件系统(使用 sshfs)挂载为 /var/discourse/shared/standalone/backups/default。一切似乎都正常,我可以在 /var/www/discourse/public/backups/default/ 中创建/删除文件或目录,但当我尝试运行备份时,它会失败。有什么办法可以解决这个问题吗?权限设置为 777。
另外,也许在软件的下一个版本中,禁用备份压缩的选项终于会出现?这样我们就可以节省几年的存储空间 :slight_smile:
谢谢!
[2023-02-25 04:41:33] pg_dump: executing SEQUENCE SET category_featured_topics_id_seq
[2023-02-25 04:41:33] pg_dump: executing SEQUENCE SET category_groups_id_seq
[2023-02-25 04:41:33] pg_dump: executing SEQUENCE SET category_required_tag_groups_id_seq
[2023-02-25 04:41:33] pg_dump: executing SEQUENCE SET category_tag_groups_id_seq
[2023-02-25 04:41:33] pg_dump: executing SEQUENCE SET category_tag_stats_id_seq
[2023-02-25 04:41:33] Finalizing backup...
[2023-02-25 04:41:33] Creating archive: p-e-2023-02-25-043914-v20230201192925.tar.gz
[2023-02-25 04:41:33] Making sure archive does not already exist...
[2023-02-25 04:41:34] EXCEPTION: /var/www/discourse/lib/discourse.rb:137:in `exec': rm: cannot remove '/var/www/discourse/public/backups/default/p-e-2023-02-25-043914-v20230201192925.tar': Permission denied
[2023-02-25 04:41:34] /var/www/discourse/lib/discourse.rb:171:in `execute_command'
/var/www/discourse/lib/discourse.rb:33:in `execute_command'
/var/www/discourse/lib/backup_restore/backuper.rb:216:in `create_archive'
/var/www/discourse/lib/backup_restore/backuper.rb:40:in `run'
/var/www/discourse/script/spawn_backup_restore.rb:9:in `backup'
/var/www/discourse/script/spawn_backup_restore.rb:31:in `block in <main>'
/var/www/discourse/script/spawn_backup_restore.rb:4:in `fork'
/var/www/discourse/script/spawn_backup_restore.rb:4:in `<main>'
[2023-02-25 04:41:34] Deleting old backups...
[2023-02-25 04:41:34] Cleaning stuff up...
[2023-02-25 04:41:34] Removing '.tar' leftovers...
[2023-02-25 04:41:34] Marking backup as finished...
[2023-02-25 04:41:34] Refreshing disk stats...
[2023-02-25 04:41:34] Notifying 'siteadmin' of the end of the backup...
[2023-02-25 04:41:42] Finished!
没人?有什么办法可以修复它(除了某种我不知道的,通过 ssh 隧道进行 nfs)? :frowning_face:
磁盘很便宜,Discourse 迁移是最简单的迁移之一。可能值得考虑迁移 VPS。如果你目前无法进行备份,那么像 PostgreSQL 升级这样的事情将是完全无法进行的。
对于大多数人来说,投入时间在这上面是不值得的,因为时间比多出来的几 GB 更宝贵。
您好!
这很可能是因为 Discourse 的备份过程是以有效的用户 ID 0 运行的,因此您可能需要将 此选项 传递给 sshfs
sshfs -o allow_root SERVER:PATH MOUNT_POINT
或者,如果您使用的是非特权容器,则改用 allow_other
你愿意捐赠一些便宜的磁盘吗? :wink:
谢谢,我会试试的。这很有道理。 :+1:
