So, I have installed and reinstalled my discourse at http://forosdeinmigracion.com probably more than 10th times. The SSL Let’s Encrypt would work with no issues, but suddenly, after installation, my server can’t get to resolve Let’s Encrypt. So I had to disable SSL from app.yml to have access to the site.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
However, my I rebuild the app after commenting lets encrypt I am able to access the site
I found out that I reached the limit of free ssl with Let’s Encrypt. I went ahead and follow this steps Allow SSL / HTTPS for your Discourse Docker setup but I did not get it to work. Any step by step (beside the one in the link) to set up my purchased SSL cert?
I figured it out.
Johnny
You’re limited to 50 certificates per week, 100 domains per certificate and 10 duplicates in any 7 days, so whenever the 7 days are up you can re-enroll.
