SSO payload can be seen be moderators again?
A bug was reported by anon60302432, where moderators could see the SSO payload containing the email address, despite the “moderators can see emails” option being disabled. After investigation by techAPJ, it was determined that the issue was due to the payload being visible to moderators. A fix was implemented to hide the SSO payload for moderators, and further discussion is underway to potentially require a button click for admins to access the payload. The issue was also found to be related to the use of “email” instead of “external_email” in the SSO payload, which is expected to be saved as external_email in Discourse.
was Moderators should not see emails in SSO section - #13 by techAPJ reverted? It seems moderators are able to see the payload (which contains the email) again.
Not sure, @techAPJ can you have a peek when you are back?
I am not able to repro this on latest Discourse version.
Note that moderators will see the SSO payload but that payload will not contain external_email.
Is it possible to restrict visibility of the entire SSO section for mods?
Just updated to beta 3 and ran a test. Account only had moderator, last payload included the email even with the “moderators can see emails” option disabled.
email=
external_id=
name=
nonce=
username=
I noticed you mentioned external_email but on our payload its “email”, not “external_email”, maybe that’s why? Is that something we need to fix on our end?
To add on, I believe I used this post when creating our SSO process: Discourse SSO and API Helper for PHP. Uses “email” as one of the parameters, not “external_email”
@techAPJ
Thoughts on the above? ^^
Are you talking about the /admin/users/{id}/{username} page or somewhere else?
No, when the SSO record is created the external_email is saved as per:
In reference to:
email=
external_id=
name=
nonce=
username=
Where are you seeing this payload in Discourse? As you can see above the email is saved as external_email, name is saved as external_name, etc.
Aha, I see that the payload is visible to moderators. I’ve hidden the SSO payload for moderators via:
https://github.com/discourse/discourse/commit/901d6080df6a62c8fbb4da697a9150fdd93211da
We’re also discussing if the payload should be behind a button click for Admins (like we do for emails).
Thanks for the excellent report @anon60302432, and for persistent follow-up. :trophy:
